Wideband data for 3.2 getting 10 mpg city - what do you think?
Engine’s an ‘85 3.2 in an ‘80 911. City mpg is at 10. Highway 27. These results have been double checked. City used to be 18. Drop to 10 mpg occurred at some point during engine's rebuild. Don’t think there’s any need for engine or rebuild details given the wideband data clearly speaks for itself. The issue in hand here will be immediately apparent---O2 delta between 1-2-3 and 4-5-6. Wideband = Bosch 4.9 sensors, Innovate controllers, LogWorks software. To rule out hardware error, sensors were swapped side-to-side as were controllers. Test data remained consistent.
My prior thinking as well as that of others was this being a fuel injector issue. On seeing the wideband data here, and given the injector testing as was done, the finger (in my mind) is now pointing to either the ECU or the injector harness cable. Am interested in alternate views—please see what you think. I’ll put rebuild notes at the end as I know this matters to some. Warm engine at idle tests: Green trace = 1-2-3 side of engine Blue = 4-5-6 Vertical axis = Lambda Horizontal = Time in seconds ![]() Idle mixture screw out 5 turns Lucas injectors W6DPO Bosch spark plugs ![]() Idle mixture screw out 5 turns Bosch injectors in 1-2-3 / these are original to engine #0-280-150-158 Lucas injectors remain in 4-5-6 NKG Iridium spark plugs installed ![]() Same config as prior setup only with… Idle mixture screw now turned out total of 7 ¾ turns Here's interesting part… The remaining Lucas injectors in 4-5-6 are removed and replaced with Bosch injectors. Engine now has all Bosch injectors… idle mixture remains at 7 3/4 turns out... ![]() Expectation at this point was to see both O2 trace lines nearly overlapping, that being on the potential that the Lucas injectors failed to some degree—and—there being fresh Bosch injectors with even flow now installed. Instead, the wideband pattern of the all-Bosch injectors is uneven side-to-side just as with the all-Lucas injectors. Bosch are indicating richer than Lucas. More injector detail to consider… Bosch injectors were removed from the engine years ago and shelved. While the wideband system was being installed here, the Bosch injectors were serviced by Mr. Bill. His report… ![]() The Lucas injectors that are now removed from the engine were installed and in service for a number of years prior to the engine’s rebuild. They did deliver 18 city mpg. This fact together with O2 wideband profiles for the all-Lucas and all-Bosch injector config looking similar, and the combo wideband of them being "unusual" in this case… a smoking gun as I see this. IOW.. Injectors don’t seem to be at fault—something else is afoot. Spark plugs cannot be the cause of the delta anomaly seen but am noting them changed as a matter of record. The switch from W6DPO to Iridiums was advocated by Sal and Ivan---who I credit knowing far more than I about this stuff. While switching plugs, made sense to test compression. Was done with roughly a 2 second crank and the fuel injection harness disconnected. I suspect cranking longer would result in higher psi. In any case, purpose was to rule out the presence of any cylinder failures. Was good to confirm...TY Sal. ![]() ![]() W6DPO plugs that just came out. These were pulled, cleaned, and reinstalled about 500 miles ago when I started into this 10 mpg puzzle. In reality, the color here is more brownish than is seen on my screen. Engine profile for the interested… Mods from stock during rebuild: 964 CamsStock: Heads rebuilt to spec by Xtreme - new valves & guides, seats facedAfter the rebuild and once on the road, power to redline was there through all gears. Were it not for fuel & mileage gauges staring at me, I’d not be writing this. Immediately, and with little Motronic experience I admit, I molested fuel-things hoping for a quick fix. AFM disk, ECU fuel setting screw, mixture and idle screw being included in my initial forray. Varying degrees of performance resulted. Obviously no quick fix was had. As the engine now stands, everything that was molested has been returned to original settings with the exception of the idle speed and idle mixture screws. Warm idle is a steady 850 rpm. Mixture screw is 5 turns out—now changed to 7 ¾. Did city and highway wideband recordings. That collection is largely redundant so am not positing that stuff. Does exist as good baseline fodder should it be needed. WOT to redline may be of interest... ![]() This is with Bosch-Lucas injector combo. Did not get to redline in 4th and no 5th at all. For you who suggested my getting into wideband... you were absolutely right. I regret my hesitation as it now stands. Thank you for egging me on-and-on! .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 11-11-2024 at 05:29 AM.. Reason: Added "to redline"... |
The W6DPO plugs are not correct for the 3.2, you need standard plugs with normal simple ground strap like these NGK 6637 BPR6EIX Single Iridium Spark Plug
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
If the stock injectors are causing different reading between banks you likely have a bad flowing injector. I suggest you swap 1-2-3 injectors with 4-5-6 and check AFR again. If the AFR readings swap banks you know it's the injectors.
Be very careful with used injectors, even if they have been cleaned and bench tested they can easily still not work properly in car because of age.
Your idle mixture target should be 0.95 lambda NOT 1.0
The idle mixture is always set between 13.8 to 14.4 AFR
One more point: if you look at the intake you will notice that the throttle body is skewed toward the driver's side, this favors air flow slightly to to 1-2-3 side. Meaning that you get slightly more air flow toward that side, the air is not 100% even between 1-2-3 and 4-5-6 but it's not much different. And if the air favors the 1-2-3 side that would result in slightly leaner reading on that side but what you have shown above is that 1-2-3 runs richer than 4-5-6.
Again, my suggestion is swap stock injectors between banks to be sure it's not injector related. Then, within the DME it has only one single transistor that fires all 6 injectors at once, I doubt the issue is DME internal. But it could be injector harness related, be sure the big harness plug near the drivers shock tower is clean and tight. Also with key in RUN engine off check the 12volt pin of each injector harness that plugs into the injector. Be sure they all have exact same voltage reading. You can also check that voltage level with engine at idle for each injector, you will need to back probe the injector plugs to do that.
Sal... Iridiums are installed. They went in with the compression tests.
.95 lambda at idle. That was hit with the Bosch injectors in for 1-2-3, Lucas in for 4-5-6 and the mixture screw at 5 turns out. Leaving that mixed injector combo in the engine danced in my head... Couldn't do it, even to just test mpg. Just spoke with Bill (Mr. Injector) about the injector wideband readings. He leaned toward the situation NOT being injectors but did not take a bold stance on that. Mentioned I'd be sending him the Lucas to see where they are at. He said send the Bosch too and he'd recheck them under warranty. Your idea for swapping injectors is another fine idea. Is on the menu with a wrinkle... I just sent the ECU to ProgRama in Boca to check it. When it comes back, either it is good as is or there was an issue with it... and Joseph fixed it. If there is a fix, I'll install it and of course wideband it immediately. If ECU checks out good without needing a fix, am swapping the injectors as you suggest. Injector harness... running 12v through it tomorrow. By the way, wideband... You played a large role in that happening here. Thank you for the repetition of advice in that regard. More, you're a supernova of all this air-fuel intel. So more thanks your way for raining it down on the arena I'm dancing in here. .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Could there be an exhaust leak? Intake leak?
'81 911 SC '03 BMW M3 (Sold) '64 VW Beetle, 2332, 48 IDA (Sold) Instagram: @j_smallwood |
From what I've seen of the ProgRama "repairs" over 20 years, it shouldn't have been even considered. Good Luck!
Dave |
Also, nothing you showed so far would result in 10MPG city. If anything you should be getting decent MPG running lean in 4-5-6
It's still a mystery, what's the cause of 10MPG? When you noticed the 10MPG was the stock O2 sensor installed and connected? And now it no longer is in use?
Just noticed you are using a non stock ignition coil?
Blaster coil? Do not do that, please install a stock coil. The DME is fine tuned to properly charge the stock coil. See my video on what it takes to understand coil charge times and every coil is different. https://www.youtube.com/watch?v=a7dFdIdsZeU
to develop the next spark energy. It operates basically the same as a points ignition system, not like the later ignition systems where the time delay for spark energy development varies based on RPM. Oscilloscope waveforms of the DME ECM pin 1 verify this. When Blaster coils are used in a 911 3.2, they provide a spark energy basically the same as the OEM Bosch coil, based on their tested parameters as provided here; Typical Ignition Coil Values: https://www.systemsc.com/diagnostic.htm As indicated by the coil parameters of the two Blaster coils and the OEM Bosch coil (911 TCI), the electrical parameters are with 10% of one another. Furthermore, since the coil series resistance is a little higher on the Blaster coils, less heat will occur to the DME ECM output transistor coil driver when coil current saturation occurs.
Dave Last edited by mysocal911; 11-13-2024 at 06:42 PM.. |
![]() I have tuned this table for different coil types in the past. Is the blaster coil similar to the stock coil specs, that I don't know but I take your word for it. Or one could bench test it to find out the exact time it takes to fully charge and saturate the coil and various voltages.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 11-14-2024 at 05:22 AM.. |
Joe... could be but doubt it. Intake nuts were changed a few months ago to narrow nuts and torqued. Exhaust I checked a few weeks ago but not all of them. On your note, will check them all to confirm one way or another.
Whether the imbalance side-to-side is related to 10 mpg or is a separate puzzle is also unknown. Am prioritizing solving the imbalance. Perhaps the 10 mpg will solve with it / perhaps not. I hope the ECU is at fault for both issues! Quote:
Setting mpg and O2 imbalanced engine sides aside... engine idles well and pulls with power to redline through the gears. I say this as reference while not knowing what difference would be evident between running a Bosch or Blaster coil. Quote:
If anyone has a source for the original black Bosch coil, please post it. Should be hearing from Joseph at ProgRama today or tomorrow. .
Karl, just curious to know if you are now running open loop or closed loop. If closed loop, since you now have a setup with two wideband sensors, which one of the O2 controllers did you plug back to the Motronic ECM? And have you tried to swap them? It is probably a stupid question, but since the Motronic only has one input for the return signal, just asking anyway.
Gilles RoW 88 Carrera coupé |
Tested injector harness for integrity yesterday. (This should have been done before sending ECU out so am guilty---cart before the horse here.)
![]() ![]() Pin 14 serves 1-2-3 side of engine. Pin 15 serves 4-5-6. When looking into connectors to injectors, and with connector's quick-release bar facing down, full continuity runs to right side female slot. Harness is good --- 12.64v from ECU plug to all 6 injector connectors. .
I did swap the O2 sensors side-to-side in the exhaust after seeing the first trace lines... (green is 1-2-3 side / blue is 4-5-6, scale is lambda.) ![]() Had to question if imbalance seen was a sensor or controller fault or truly the exhaust O2 levels. I also swapped the Innovate controllers. Readings did not change for each side of the engine. I concluded hardware was working correctly. .
I may be overlooking this answer, but could the DME be reading the lean side to over correct fuel dose and driving down the mpg? You probably wouldn't feel this in the power of the engine, but it would definitely show up in fuel use.
These engine do not like to idle above 1.0 lambda they will lean misfire at idle if lean. That's likely the cause of the spikes in lambda on the 4-5-6 side. The green line for 1-2-3 looks like decent lambda around 0.95 and that's a good setting for mixture.
The mystery still is why are the 2 banks so different? My suggestion is swap injectors from RHS bank to LHS and see if the issue moves to other side. If it does it's an injector issue, if it does not you likely have a air leak on the 4-5-6 side. I really suggest swapping injectors and using only the stock injectors. The other test worth while is a cyl balance test unplugging one injector at a time and observing what that does to AFR, if one injector effect AFR more than another sister injector on that same side you know that cyl is having an issue. Also spark plug color is worth looking at. The WBO2 data is ONLY one data point, you can't put all your faith in just one data point. For example: maybe you have a air leak at the head gasket in cyl 4? that would make you think the entire bank 4-5-6 is lean but it's not, you may have 5 and 6 running on target and only 4 is lean because of a cracked plastic spacer or gasket at the intake port. Remember, the WBO 2 sees the average O2 in the exhaust stream from all 3 cyls
One more thought, double check firing order of the dizzy and be sure the spark cables are going to correct cyl. Firing order is 1-6-3-4-2-5 (clockwise rotor rotation). No disrespect here, but I've seen stupid things cause issues in the past
![]() Also the 964 coils are exact same part number as the stock 3.2 and you can find plenty of used good ones on ebay and you get 2 coils for a decent price. They are the good German black ones, just search for "porsche 964 coils" I see a set of 2 right now for $49Enjoy!
So at 6K RPM with a spark duration of 1ms, this leaves about 2.3 ms to charge the coil for the necessary spark energy. Once one knows the key parameters of an ignition coil, no actual in circuit testing is needed.
Dave Last edited by mysocal911; 11-14-2024 at 02:02 PM.. |
