3.2 Carrera no run
We have an 87 Carrera that came in with the complaint that it from time to time will crank but not start. It will maybe the next day correct it self. we have had it a couple of weeks and experienced this twice. Installing a test DME relay and DME unit is not the cure. We have spark, fuel, and injector pulse. What am I missing. Bob
I meant to add this, we have replaced the 2 speed sensors and CHT
Years ago I had a similar problem coil had a periodic fault.
Bruce |
Bruce has a great suggestion. If it has the new silver Bosch coil, those are at best 50-50 odds of bad out of the box.
Find 40 year old Bosch black coil and try that. The 964 coil is one possibility of a new coil for a 911 G body car.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
You can find parts like these at European salvage yards. I have. The black coils probably were used and different model cars.
Bob,
Have you tested the fuel pressures? The FPR could be bad. Test and verify. Tony |
no run
I have not checked pressure or delivery and at the moment she is running. I just looked to see if fuel was coming out of the fuel rail under pressure. Other than leaking due to a ruptured diaphram, how would the FPR keep the car from at least emmiting some sort of combustion. I appreciate your response. Bob
one little thing
check the ground connection on intake no 1 Ivan
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Next time spray some starting fluid into the intake. Quick way to determine if your problem is missing fuel or spark.
Senior Member
Similar issue with 88, think it was part check valve and failed FPR.
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
Dave |
PCA Member since 1988
Agree. You should carry a can of starting fluid in the car. Spray it in the intake when the car won't start to determine whether you are missing fuel or spark.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Senior Member
I would check the CHT as well. Failed FPR can flood the car and preclude starting. Worth checking for fouled plugs.
FWIW, I had an intermittent starting issue in my '87 a bit ago. It turned out to be the wire harness connection for the speed sensor. When I replaced the connector (at the top-back of the engine, where the 3 connectors mate to the 3 sensors), the problem was cured.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
I do think the problem is solved. Since it was intermittent, will have to give it some time though. So we had fuel pressure, spark at a grounded plug and injector pulse but car from time to time would not fire. Customer stated that seemed to more of an issue on damp days. Resisted installing a coil as it appeared we had a healthy spark and the only coil at the time available to me was the silver Bosch coil which had a bad rap. I finally ordered a coil out of desperation. Upon switching out the coils, found moisture at the connection, the center cable to be corroded as well as the port in the coil. The new coil immediately fired the engine, cleaned everything up and the existing coil did as well. So if a spark looks good, may not be. Thanks for all responders. Bob
