1979 Porsche 930 engine sound
After a short drive, I couldn’t help but notice this sound. After reading different threads on failing timing chain tensioners or valve jobs, it doesn’t quite sound like that to me. So I’ve made a video. I’m contacting my pro-mechanic, but in the interim here it is.
Here’s what I see so far: Stars/occurs once engine is warm Definitely on the lower end Roughly 2,000 miles since full rebuild It is not a consistent sound Doesn’t go away after 2,000rpm Using a wood stick trick, I cant (yet) find it https://m.youtube.com/watch?v=12g1SpmeK2g Last edited by mic034; 12-10-2024 at 03:16 PM.. |
An engine cover / air duct plate / heat shield have loosened and is rattling now?
Check the heat exchangers and the exhaust too...probably sth has loosened inside.
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 12-10-2024 at 04:00 PM.. |
Thank you. Good idea about the exhaust and heat exchangers…I haven’t thought of that. I’ll get it on my lift and have a better view of it and use my probe later this week.
When I heard this on my car it turned out to be the engine tin was loose, but I am not an expert.
Check the 10mm hex bolts holding the tin pieces together. Just a guest...and, Good Luck.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
