Some years ago the door lock jammed on my 1978 SC. It turned out that a small circlip (snap ring) had come off that holds the spring circled in post #17. This snap ring can be seen half way along the rod (in the red circle). I fixed the problem by installing another snap ring. Perhaps this is the problem?
Roy
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
I think something must have jammed. It is working OK now. But I would like to find what happened.
I have found in my pile of bits, and old door lock mecahnism - complete with the rod to the square lug. Just trying to figure how that bit works. Thanks Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Post a pic of the lock assembly that you have. there are a few variants, with subtle differences (primarily to the internal door handle lock), but they generally use the same concepts. If you post a pic it can help with the specific discussion.
Good that you are in!
Consider this...
76FJ55, you have posted some excellent info on other threads I searched.
Here is a lock which I believe is out of an 82SC. My problem was on the 82 930. So I am figuring it is the same lock. That rod goes to the interior knob I believe. I have been fiddling with this on the bench and still can't get it to work (unlock) via pulling the rod. Anyway - if you have any suggestion as to what might have got jammed, feel free. Thanks Alan
