1972 911 thermo time switch
I have a 1972 911T MFI that is leaking at the thermotime switch. Does this sensor have a gasket o ring or washer installed with it?
Yes. Flat copper ring.
Thanks!
Banned
Yes, the thermotime switch on your 1972 911T MFI typically uses an O-ring to seal it and prevent leaks. If it's leaking, it's likely that the O-ring has degraded or was not properly seated.
