Kangaroo just off tickover
Odd problem, I have a 1987 911 completely standard.
When I start it from cold it will drive ok but with a fraction of throttle applied it will kangaroo (drive jerky) a bit, once the throttle is applied a bit more it is fine, this will happen at any speed, even if driving say at 50mph, take your foot off the throttle and just feather it and the car will jerk back and forth. this still happens when the car has warmed up. BUT park up and stop the engine for 10 mins restart and the car drives as smooth as a Swiss watch...Any ideas? |
OK, I've actually found the problem. I initially thought ICV, I had previously replaced this and it did help a little but the problem was still there. It actually turned out to be a problem of my own making, if I'm not going to use the car for a few days I disconnect the battery from my reading this looses some learnt settings from the ECU and reverts it to factory settings. I drove it yesterday and did my usual drive until it's warm then switch off and restart, I left the car overnight (with battery connected) and used it again today and it's perfect.
I chased a hunting idle, jerky throttle, engine shut off, etc. Replaced ICV, O2 sensor, head temp sensor. Was the idle screw turned out too much. Adjusted that and problem solved
'86 944T black/red, chip, fuchs 8's and 9's- Sold '97 Boxster silver/red, big mistake - Sold '99 C2, silver/black, RoW M030 - sold "69 912 white w/ '86 3.2L (like the pic, just not the pic) |
If your problem has disappeared, it must be a coincidence.
Gilles RoW 88 Carrera coupé |
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Hunting idle at start up was due to idle bypass screw open too far. Jerky off-idle fully solved by relocating AFM potentiometer tracks, and installing a new O2 sensor, combined with properly adjusted bypass screw. |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
1986 Carrera 3.2 Coupe in Grand Prix White IG: @c.cal.porsche |
I've had this problem since I rebuilt the car over 5 years ago and I've never fully solved the problem, I did have the ECU rebuilt, I've replaced the ICV, fuel pump, fuel pressure regulator, and this was the only problem that remained, it was worse when driving in a traffic queue just around tick over. I've been using the car more and more lately and just noticed that when I park-up and go back to it it then runs perfectly and now when I leave the car for long periods with the battery connected (a number of days or even a week) the car starts and runs perfectly. Like you I'm surprised that an ECU of this age had a "learning memory" (or whatever it is called) so it could well be a coincidence BUT is is definitely something to do with the battery being disconnected.
From memory, The DME relay completely disconnects the positive power to the ECU when ignition is off, so not sure how leaving the battery connected solves your problem, more likely a slight air leak somewhere, or AFM needs the tracks inspected as they tend to cause drop outs in the resistor track over the most used part of the track, had the same issue with mine, moving the wiper in the AFM to an unworn part of the track sorted the issue for me, also; inlet manifold bolts can creep loose over time, allowing unmetered air to enter the cylinders, so another possibility ?
Ant.
