-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   torque setting (http://forums.pelicanparts.com/showthread.php?t=1176735)
targabill 04-22-2025 08:13 AM
torque setting
Hi, The manual I have, Haynes, is almost useless at times.. What is the torque wrench setting to the 13mm Valve cover bolts.. Putting new gaskets in..
Thanks Much,:cool:
-Bill
1982 911 SC Targa.
flee27 04-22-2025 08:24 AM
I agree with you opinion of the Haynes manual. From my research I went with 6 ft lbs.
Tighten in a few steps from the middle out.
Best
Foster
targabill 04-22-2025 08:44 AM
Thanks Much... 6 it is.. Yeah I will do the criss cross pattern..
Otter74 04-22-2025 05:30 PM
This is basically snug plus a quarter turn, maybe half.
PeteKz 04-23-2025 08:39 AM
Agree. Do not whack it down 15-18 ft-lbs, even though the M8 nuts/studs would normally take that torque. If you do, you are likely to warp the covers.
