torque setting
Hi, The manual I have, Haynes, is almost useless at times.. What is the torque wrench setting to the 13mm Valve cover bolts.. Putting new gaskets in..
Thanks Much, ![]() -Bill 1982 911 SC Targa. |
I agree with you opinion of the Haynes manual. From my research I went with 6 ft lbs.
Tighten in a few steps from the middle out. Best Foster
Foster Monroe, Ga 1984 911 Carrera Targa |
Thanks Much... 6 it is.. Yeah I will do the criss cross pattern..
This is basically snug plus a quarter turn, maybe half.
'80 SC Targa Avondale, Chicago, IL |
PCA Member since 1988
Agree. Do not whack it down 15-18 ft-lbs, even though the M8 nuts/studs would normally take that torque. If you do, you are likely to warp the covers.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
