Free minder
Thanks Andrew, I will look into that.
At least I realized all my coils are good. I was only measuring a low secondary resistance because the multimeter battery was low, duh…
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Free minder
I am using newer MSD streetfire CDI boxes (and I have a spare one).
Free minder
I just checked the AC voltage at the green wire while cranking, and it is 0.6V AC, so it confirms the dizzy coil is good. The plot thickens…I will get the little oscilloscope to check the signal shape.
Next steps:
1. Check inductive signal (as shown above) at pin 7 of the CDI 2. Check for proper Voltage (12v min) at pin 15 of the CDI 3. With a high voltage probe (x100) measure the signal between the CDI and the CDI-Coil (pin A). And this waveform should result : https://nineelevenheaven.wordpress.com/wp-content/uploads/2023/12/bildschirmfoto-2020-11-27-um-00.34.35.jpg Part of this site: https://nineelevenheaven.wordpress.com/the-ignition-of-the-911-3-0-and-3-2/
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 05-15-2025 at 01:59 AM.. |
PCA Member since 1988
Sorry I missed that in your first post.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Good point! Then, most likely the typical distributor signal for the Bosch CDI is not compatible with the "newer MSD".
Dave |
Free minder
The car has run flawlessly for over 10 years with the MSD CDI box and the Bosch distributor. Something else happened…
Are you getting spark at the coil wire before it enters the distributor cap ? A worn or defective carbon button could keep the spark from getting to the rotor.
Right, he needs to use a scope and check for a signal (~ 350-400V peak) at the coil!
Dave |
Free minder
Btw, my little scope just arrived, so I will be able to check the signal at the green wire, if I find time this WE.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) Last edited by Aurel; 05-16-2025 at 04:32 PM.. |
If that is not the case , is the MSD box is getting 12v while you are cranking ? |
Free minder
OK, I got busy this morning. First, the signal at the green wire looks good, see the trace below: ![]() Second, the voltage to the CDI box is 13.1V at rest, which is fine. ![]() But when I crank, the voltage drops to 10.5V, which may be too low for the CDI box? ![]() Also, if I trigger the CDI box with the white wire, I get a spark at the coil, but if I crank, I get no spark at the coil. This also suggests the voltage to the CDI box is too low when cranking. ![]() So maybe a bad ground is causing too much voltage drop when I crank, or maybe the battery itself is bad, but it cranks the engine with no issues. At least, I think the distributor is not the source of the problem.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) Last edited by Aurel; 05-17-2025 at 09:24 AM.. |
Dave |
If you are using the white and black wire from the MSD on the SC distributor to try and trigger the MSD you are using wrong connection. The white wire is for point or pertronics type signal. You need to use the purple and green wires labeled for mag pickup as that is the type of output from a SC distributor.
john |
Free minder
If you have enough battery charge to crank the engine, that's more than enough to power the CDI. A voltage drop to 10.5V during cranking is normal. The battery ain't your problem.
However, if you connect another battery in parallel, like when you jump start a car, and it still doesn't fire, then you can be certain the battery is not the problem.
Resolve the issue by connecting a jumper battery at the starter.
Dave |
Free minder
I have always used the MSD by getting its power at the 3 fuse box in the engine compartment, without issues for over 10 years. Also, MSD datasheet says it will fire with as little as 7V, so I am not sure that will resolve the issue (but will try).
Marginal if any benefit from a MSD, found this on Pelican Parts; http://forums.pelicanparts.com/porsche-911-technical-forum/676385-msd-ignition-exposed.html
Dave |
Free minder
Now is time for an update. I finally figured out what was preventing sparks, and now have ignition again.
I checked again the voltage at the CDI box, and even without cranking, it was only 6.5-7V. The voltage at the front fuses was a solid 13V, and the voltage at the engine fuses was only 6.5-7V. I checked my ground connection but that was fine. I opened the 14 pin connector, and sure enough there was a connection holding by a thread that broke immediately. I resoldered it and voila, my ignition is back.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) Last edited by Aurel; 06-01-2025 at 03:08 PM.. |
