Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
help with rear wheel bearings
all,
im replacing the rear wheel bearings on a 1984 Carrera and it seems that one side is different than the other. i checked the part number in question and its a 9113315140R. i ordered two bearings for the 84 and then discoverd that the bearing in that one side did not fit. i always thought the bearings were the same from 74-89. what is the correct rear wheel bearing for that control arm??? is there a chance an oversized bearing was used? is that even possible? i measured right at 83mm outside diameter of the big bearing. the othere side was 80
thanks!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 05-01-2025, 12:53 PM
Is it possible one of the rear trails arms was replaced with one from a different year?
Old 05-01-2025, 05:38 PM
