Black and Blue
replacing fuel lines...left right...supply return
all,
if i am installing fuel lines thru the tunnel, which side is the supply and which is the return...im standing in the hole where the fuel tank is. i just want to do it the oem way. thanks!!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
On my 87, supply line came in on left driver side and return line through the right passenger side of the car. This pic is looking into the tunnel with new lines and rubber grommets. Many threads and fuel line supply expert Len Cummins provided immense help.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Location: behind the redwood curtain, (humboldt county) california
+2 for Lenn
He also supplied new front rubber flex lines to go from the new tank to the pump, the line to the front firewall and the flexible line from the front of the tunnel, back to the tank.
Being the cautious type I asked him to make up some stainless flex lines from the rear of the tunnel to the filter and a return line from the pressure regulator for the new Kosmal supplied MS/PMO EFI system. chris |
