Engine Oils Fact or Fiction
My mechanic, who was considered reputable at one time, is dead set on the fact he has lost multiple engine rebuilds over the past two years due to new standards for engine oil.
He has had two rods fail in the crank post rebuild twice and claims the remedy is a larger 964 Oil pump and use Lucas Hot Rod oil. The mechanic mentioned he’s been rebuilding Porsche engines for 30 years, relatively the same way, yet now they are all failing. I’m curious if others are seeing this with rebuilt rebuilt engines regarding the oil or my mechanic is just way past his prime.
Old 05-13-2025, 12:52 PM
Seems....strange to me. Valveoline VR-1, Castrol dyno oil in 20-50, Liquimolly 10-16......lot's of oils are very reputable out here and work very well with no issues. Not running an oil designed for older motors, with the ingredients they need, can be an issue over the long term. Not sure they would cause short term issues on a rebuild. In my little bit of experience.....can lobe wear it a common issue with the "wrong" oil.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-13-2025, 01:13 PM
PCA Member since 1988
Fiction. See the reply on your parallel thread.
Old 05-13-2025, 01:29 PM
Yes, it seems odd to me too he claims he’s been rebuilding engines for 30 years the same way but all of a sudden is losing engines over the past couple years because of the ingredients being taken out of oils.
Old 05-13-2025, 02:52 PM
dictoresno's Avatar
and was considered "reputable at one time", but apparently not now.
if anything, oils have gotten better over time (base stock and additive packages), so I doubt anything on the oil side is ruining his builds.
what oil was he using "before" the issues stared happening and what oils were his new builds using when they failed?
1986 Porsche 911 Carrera 3.2
Old 05-14-2025, 08:36 PM
The wisdom does seem to be that modern oils are better, but are they just better for modern engines with tighter tolerances, so not necessarily better for older engines with less tight tolerances? I’m not saying this is the case as there’s always much conjecture on oils but it could be the case.
Old 05-14-2025, 11:17 PM
E Sully's Avatar
Modern Oils are better for modern GDI and turbo engines, but definitely not for flat tappet engines. There are good oils for our flat tappet engines, but chemistry changes all the time. Diesel oils are no longer good due to chemistry changes for modern Diesel engines emission requirements.
I had a Thread about the science behind oils today, but for some reason one of the Moderators decided to close it and merge parts of it into another oil thread with no explanation.
Ed
1973.5 T
Old 05-15-2025, 11:40 AM
Bill Verburg's Avatar
There is a very wide selection of oils available out there.
It's not at all helpful or informative to not list which specific oil he has a problem w/
Bill Verburg
Old 05-15-2025, 11:58 AM
Still here
pmax's Avatar
It's beginning to look a lot like an oil thread !
Old 05-15-2025, 12:56 PM
Yeah, this is getting highjacked. He was asking about the rod bearings failing, and that ain't due to the oil, modern or ancient.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-15-2025, 01:36 PM
I would be more inclined to blame the quality of bearings before I blamed the oil.
Rutager West
Old 05-15-2025, 01:54 PM
he did ask about oil
Bill Verburg
Old 05-15-2025, 02:50 PM
I would think that if there was such a problem with the newer oil, that it would affect the cam lobes and rockers before the rod and main bearings. I use an additive with ZDDP which modern oils don’t have. Removed by the “Greenies”. It is a must with Flat tappet lifters of yesteryear. I also find it criminal that the feds are forcing auto manufacturers to have a corporate average fuel mileage across the fleet. CAFE is total BS. Each manufacturer has a product line. They sell or don’t sell cars based on what the public wants to buy. Everything is not equal. To get to the acceptable BS CAFE value, they use a thinner oil and boom! Sometimes is doesn’t work. Case in point, GM’s current dilemma with LS engine failures. I doubt that using any good modern multi viscosity (10-40 of 20-50) oil with ZDDP would fail if the engine is assembled properly and treated respectfully.
Old 05-15-2025, 07:18 PM
Many years ago I was working for an engine reconditioning company, and we started having an odd problem with GM engines using lots of oil after rebuilds, we tried different types of running in oil etc, nothing seemed to work, the engines would not smoke on start up, or if you revved them up standing still, however; once you got them out on the open road, they would go through oil dramatically, anyway, long story short, it turned out the guy that was boring the cylinders in the blocks had his settings wrong for this particular engine type, therefore the piston ring to cylinder gap was larger than it should have been.
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 05-16-2025, 02:17 AM
Everyone oil that removed Zinc and other additives. He recommended Lucas HotRod, due to its increase in velocity and zinc. Something about a 2020 government mandate?
Old 05-17-2025, 06:42 AM
It's a 914 ...
stownsen914's Avatar
If you do a search, you'll find lots of recommendations on this forum for oils that work well in our vintage engines. Not saying Lucas HotRod isn't good oil or anything, but I've not heard that name come up.
Old 05-17-2025, 07:54 AM
This has all been explained in detail many times, I'm not going to repeat it.
A suggestion to you, do some research
here in the search section use "oil' or "ZDDP' as search targets, you will have to do a lot of reading and decide for yourself who to pay attention to
another great source is Lake Speed he has an oil analysis business but has also posted extensively on Youtube, well worth read or watching
w/regard to Lucas oils, from what I've seen they are a bit above the high end of what what you want for a 20w-50 oil much Zinc & Phosphorus(ZDDP)
generally you want between 1100 -1200 ppm ZDDP, out side that range wear increases Lucas 20w/50 is 1600 ppm Z per their advertising, they didn't mention P in the blurb I saw
break in oi,l for short term use, is often ~2000ppm +/- ZDDP
Bill Verburg
Old 05-17-2025, 10:43 AM
E Sully's Avatar
It's important to note that just checking ZDDP levels is not enough. Lake Speed Jr talks about this in one of his videos. As I mentioned previously diesel oils may have good levels of ZDDP, but newer formulations have higher levels of detergents and dispersants to control soot which negatively affect flat tappet engines.
Ed
1973.5 T
Old 05-17-2025, 11:44 AM
It's a 914 ...
Worth noting that yeah ZDDP is important for our engines, for cam wear. Not for rod bearings.
This dude is claiming modern oil is causing rod bearing failures. That doesn't even make sense, high levels of ZDDP aren't required for rod bearings.
Old 05-18-2025, 11:27 AM
Still here
pmax's Avatar
The "dude" is a pro mechanic shop.
ZDDP was brought up by the replies here not them.
If opinions from those who rebuild engines don't count, whose does ?
Old 05-18-2025, 11:34 AM
