Sunroof headliner material function
Does this center flap have a purpose? Was going to cut off a section to repair a small worn-out area. Will cutting a small square piece cause an issue in its function?
Old 05-22-2025, 11:40 AM
you can probably cut a small section off the edge, but it is there to attach to that mid span rib. it keeps the center of the sunroof headliner from sagging.
Old 05-22-2025, 12:34 PM
ok, great. Thanks!!
Old 05-22-2025, 12:37 PM
76FJ55, do you know if its possible to purchase ONLY the sunroof headliner portion?
Old 05-22-2025, 12:49 PM
I'm sure you can have one made. when I was doing the interior of my car the headliner in general was in good shape, but the sunroof panel was failing.. As i was making some design changes to the seats I actually had a sunroof panel made with brown/tan Pasha, so yes, you can get just a sunroof panel. For reference I got mine from Classic 9
Old 05-23-2025, 04:13 AM
Tags
headlight cover , sunroof parts
