-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Can you help identify my WUR? (http://forums.pelicanparts.com/showthread.php?t=1178732)
francesconyc 06-07-2025 07:14 AM
Hello
can you help me identify my WUR, the exact bosch code or pet book code?
my car is an US version 911SC 1982 coupe 3.0 (w/whale tale , o2 sensor)
these are the images
https://i.imgur.com/zGIgu6a.jpeg
https://i.imgur.com/ENensLV.jpeg
https://i.imgur.com/pbiux88.jpeg
https://i.imgur.com/aSKZP7i.jpeg
if i see correctly my WUR doesn't have the lateral vacuum lines, only on on top.
is this the model i need?
https://www.pelicanparts.com/More_Info/911606105KX.htm?pn=911-606-105-KX-OEM
i'm asking because i would love hunting for better prices and i saw a lot on ebay and elsewhere cheaper so before spending a grand on this i want do a quick more research
thanks
RarlyL8 06-07-2025 08:00 AM
What year/engine?
We handle rebuilds on WURs and fuel distributors for all 911 CIS model variants 1973.5 to 1994.
engine177 06-07-2025 10:11 AM
Wur
There should be a number on the top. I would bet yours is a 090. Fuel Injection corp, they're in California rebuilds these. Or def talk with Rarly8.
AndrewCologne 06-08-2025 03:51 AM
Originally Posted by francesconyc (Post 12477108)
Hello
thanks
Your engine (930.16) does not need a WUR with vacuum lines. Only one vent/atmosphere hose connector on the top.
Check here in the article further below where its mentioned which one is the correct WUR for your engine:
https://nineelevenheaven.wordpress.com/the-911-sc-3-0-engine-with-catalyst-and-lambda-control/
francesconyc 06-27-2025 09:24 AM
thanks!
francesconyc 06-27-2025 09:27 AM
Originally Posted by RarlyL8 (Post 12477124)
What year/engine?
930.16 is the engine
do you also sell in exchange of core? since im not going to replace it myself i need to buy it, and give it to my mechanic, also to avoid having the car parked in their lot for weeks...
francesconyc 06-27-2025 09:28 AM
i;ll try again, it's super dirty and i need a brish probably to discover the number ;)
pmax 06-27-2025 09:49 AM
Hello
thanks
4th pic ... Move that dang hose, what is it anyway ... doesn't look OEM to me, out of the way and take a pic.
090 if it's OEM is somewhere here.
http://forums.pelicanparts.com/uploa...1751046513.jpg
RarlyL8 06-28-2025 07:51 AM
We stock all varieties of 911 fuel distributors and warm up regulators. Turn around time is typically one day from receipt of your rebuildable core.
francesconyc 06-29-2025 07:54 PM
it's impossible for me to see the number, beside the hose connected the surface seems all corroded or whatnot, so even if i could take a pic of that side it woudl be impossible
is it possible to buy thw WUR withouth the core shiptment first as i sadi i have no time for it now
PeteKz 06-29-2025 11:22 PM
Contact Tony. boyt911sc. He will end you a tested good WUR
boyt911sc 06-30-2025 07:30 AM
Sent You a PM……….
Francesco,
I sent you a PM last week offering you a WUR-090 loaner that you could test in your car without any obligation to purchase. I had sent you several PM’s before and you just ignored them. So you are not interested. Good luck with your search.
Tony
pmax 06-30-2025 09:37 AM
In that case, I would go with the 090. That should be fine.
francesconyc 07-04-2025 08:25 AM
Originally Posted by boyt911sc (Post 12490018)
Francesco,
Tony
hi, sorry for the delay, super busy with work and not usiing my car, yes im interested i sent you a PM thanks
thanks good call, is seems the overall consesus also reading other posts thanks!
