911SC '82
Can you help identify my WUR?
Hello
can you help me identify my WUR, the exact bosch code or pet book code? my car is an US version 911SC 1982 coupe 3.0 (w/whale tale , o2 sensor) these are the images https://i.imgur.com/zGIgu6a.jpeg https://i.imgur.com/ENensLV.jpeg https://i.imgur.com/pbiux88.jpeg https://i.imgur.com/aSKZP7i.jpeg if i see correctly my WUR doesn't have the lateral vacuum lines, only on on top. is this the model i need? https://www.pelicanparts.com/More_Info/911606105KX.htm?pn=911-606-105-KX-OEM i'm asking because i would love hunting for better prices and i saw a lot on ebay and elsewhere cheaper so before spending a grand on this i want do a quick more research thanks |
Crotchety Old Bastard
What year/engine?
We handle rebuilds on WURs and fuel distributors for all 911 CIS model variants 1973.5 to 1994.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Wur
There should be a number on the top. I would bet yours is a 090. Fuel Injection corp, they're in California rebuilds these. Or def talk with Rarly8.
Check here in the article further below where its mentioned which one is the correct WUR for your engine: https://nineelevenheaven.wordpress.com/the-911-sc-3-0-engine-with-catalyst-and-lambda-control/
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
911SC '82
911SC '82
do you also sell in exchange of core? since im not going to replace it myself i need to buy it, and give it to my mechanic, also to avoid having the car parked in their lot for weeks... |
911SC '82
Still here
090 if it's OEM is somewhere here. ![]() |
911SC '82
it's impossible for me to see the number, beside the hose connected the surface seems all corroded or whatnot, so even if i could take a pic of that side it woudl be impossible
is it possible to buy thw WUR withouth the core shiptment first as i sadi i have no time for it now |
PCA Member since 1988
Contact Tony. boyt911sc. He will end you a tested good WUR
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Sent You a PM……….
Francesco, I sent you a PM last week offering you a WUR-090 loaner that you could test in your car without any obligation to purchase. I had sent you several PM’s before and you just ignored them. So you are not interested. Good luck with your search. Tony Last edited by boyt911sc; 06-30-2025 at 11:56 AM.. |
Still here
911SC '82
hi, sorry for the delay, super busy with work and not usiing my car, yes im interested i sent you a PM thanks
911SC '82
thanks good call, is seems the overall consesus also reading other posts thanks!
