OsoMoore's Avatar
Cylinder 3, as seen from the intake manifold, and removing the valve cover.
Video of walk-around and intake manifold views: https://youtu.be/7dkaYhSgfvw
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 07-01-2025, 05:04 AM
OsoMoore's Avatar
Now I'm waiting a few more days for my engine yoke to arrive so I can put it on the stand. In the meanwhile I have some CV joints to repack and plenty of cleaning to do on the CIS and other removed components.
I'd appreciate any thoughts on what level of rebuild we're looking at here. Also, any tips on cleaning what's come off already!
Old 07-01-2025, 05:06 AM
You probably should start with the thinking that pieces of metal have circulated around your engine in the oil as a result of the failure. This means a full strip and clean to be sure of removal. Sorry!
Old 07-01-2025, 05:20 AM
OsoMoore's Avatar
Yeah, we're going to take her to bits I think!
I'm hoping the oil flooding seen in some of the non-smashed cylinders isn't indicative of a larger issue.
Old 07-01-2025, 06:38 AM
OsoMoore's Avatar
On the positive side, I'm quite proud of how cleanly I lifted off the CIS.
After removing the throttle anchor plate and the EGR, it all lifted off together. Helps that I have worked on it extensively in the past.
Old 07-01-2025, 12:02 PM
OsoMoore's Avatar
Yoke arrived, but won't fit on without removing some of the exhaust components. And those have been on for 25 years.
So... this morning I'm picking up a giant shallow tub (for drips) and a nut-buster to get this exhaust off. Hopefully she's mounted on the stand by this evening.
Old 07-03-2025, 05:41 AM
Originally Posted by 911 Rod View Post
No offence, but there is now way I would do this. You are now holding up the engine by the 4 holes in the case. When you use the proper yoke it presses against 2/3 of the case and spreads the weight out. The 4 bolts just keep it in position.
My 2 cents worth.
That is why the factory yoke is worth its weight in gold. I bought it 30 years ago and still use it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-03-2025, 06:27 AM
OsoMoore's Avatar
It looks beautiful and is a huge beast. I'll feel a lot better with my expensive engine on it, than on the "universal" system of sliding brackets that comes with the stand.
Now just to get these evil exhaust bolts out. Ran all over town this morning and the only nut buster I could find is too large. Ordered some smaller ones, but won't be in until tomorrow.
Old 07-03-2025, 08:04 AM
Counterclockwise?
Going to be a pain getting those bolts off without flipping the engine.
Rod
1986 Carrera
2001 996TT
Old 07-03-2025, 08:31 AM
OsoMoore's Avatar
Yep, they have been very difficult. Still have 2 left of the 3.
Old 07-03-2025, 08:42 AM
Good progress so far.
However; Like others here I am sure, I'm still waiting for an explanation of why this might have happened, i.e.; missed gear, down shifting at too high an RPM ???
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 07-03-2025, 10:21 AM
OsoMoore's Avatar
Ant.
I was flooring it out of a light, as I usually do, and just about to shift to second. Didn't hit rev limiter, although revs were very high.
I got the bolts off that exhaust section. Combination of PB Blaster, nut buster, and hacksaw. There's still a pipe to the EGR which is needs to be loosened before I can get it free. That is proving to be stuck as well.
Old 07-03-2025, 11:40 AM
I had to destroy my heat exchangers with a sawz-all to move on with my project and not compromise exhaust studs. Carry on
Bill
Old 07-03-2025, 12:47 PM
OsoMoore's Avatar
Bill
That's horrifying! I think with blaster and some time I'll be able to get this last connection up to the EGR out of the way, and get it mounted on the stand.
Old 07-03-2025, 02:05 PM
PCA Member since 1988
There's an olde tool called a nut-splitter. It was made for rusted and eroded nuts on exhaust systems. You might try that.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-03-2025, 02:35 PM
OsoMoore's Avatar
I did get the nut splitter, although I'm going to need something else for this connector to the EGR tube.
But I was able to remove the cat and squeeze the yoke past the exhaust pipe. Now I just need to get some spacers and bolt it on, probably this evening.
Then I'll try using my motorcycle jack and build a platform with bricks and such to work the engine up high enough to mount on the stand.
Old 07-03-2025, 03:36 PM
For spacers, I used plumbing pipe nipples; they come in many lengths and seemed to be strong enough.
Rutager West
Old 07-03-2025, 05:40 PM
Nikola Tesla
Old 07-04-2025, 01:36 AM
OsoMoore's Avatar
She's on the stand! I used a metal spacer I found in my parts bin, along with 2 large nuts stolen from the stock engine stand. Getting it onto the stand was a real bear. I ended up using some ramps to make a high "shelf" and set the engine on it with the motorcycle lift. Then I put the lift higher up and stacked some blocks and lifted the engine again higher, this time with a stilt to the stand's angle.
Old 07-04-2025, 06:35 AM
OsoMoore's Avatar
Then she went right on (and started dripping some more).
Old 07-04-2025, 06:37 AM
Tags
911sc , rebuild
