OsoMoore's Avatar
Now to start pulling off the exhaust. Found some interesting things.
The joint between the heat exchanger and the crossing exhaust pipe on the 4-5-6 side was full of oil. Probably half a cup came out when I opened that part up. Note that my destroyed valve was 3.
Taking off the heat exchangers wasn't as tricky as I feared. The inner bolts on the exchangers were actually just stacked with washers, maybe as a stand-off? Not sure how that worked. But that meant I just had the 8mm studs and then 3 nuts per side.
4-5-6 side was pretty oily, especially at 6.
1-2-3 was not as oily. Here's a video of her as she stands now. (May take a minute to be available).
https://youtu.be/6zh79LVmjPE
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 07-04-2025, 06:45 AM
OsoMoore's Avatar
Video of the from the top. Three is the boomed cylinder.
Video from the bottom.
Old 07-04-2025, 04:05 PM
OsoMoore's Avatar
Obviously I want to know why this happened.
Is there anything I should note, record, or measure as I take things apart to help me identify the cause? I'm trying to take a lot of photos and some good videos, but I don't know what to look for besides "the broken parts" and "lots of oil/dirt" where it shouldn't be.
Old 07-04-2025, 08:18 PM
PCA Member since 1988
Take pictures as you disassemble it. The valve guide is gone, so I would want to know where that went.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-05-2025, 12:10 AM
Originally Posted by ant7 View Post
Lots of help available here when your ready to pull it apart, just take your time, and inspect everything methodically as your removing it, label things your not sure about, and take plenty of picks as you go along for your own reference, they will come in handy when asking questions, and help with re-assembly etc.
Good luck with it
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 07-05-2025, 05:29 AM
Good work, Opening the chain box covers should be enlightening. I noticed in the video the sump cover is on, did you take it off to drain the oil and then put it back on ?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 07-05-2025, 06:42 AM
OsoMoore's Avatar
I did not take it off yet. Should I do that now?
Cam housing covers are now off. I need to identify the correct Porsche Tool(s) to remove my camshafts. I took some careful pictures, so that should help me identify the right ones.
Then while I'm waiting for the special tool, I can clean things up.
Old 07-05-2025, 07:15 AM
Start by Tearing it down to the case, pull all the oil plugs and piston squirters. This thread should be over in the engine forum.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 07-05-2025, 08:52 AM
OsoMoore's Avatar
Aha, engine forum! I didn't even think of the fact that there's a rebuild-focused subforum. Here's a new thread - I'll make future updates over there.
Engine Rebuild Subforum Thread
Old 07-05-2025, 09:37 AM
Originally Posted by 911 Rod View Post
You really need the proper yoke. I like the heavy duty stand for stability and you can put a tray under it.
hi Rod
i know this is off topic, but how loud is that exhaust setup your're running?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 07-06-2025, 05:20 AM
Counterclockwise?
Hi Mike. Pretty loud WOT. Burbles a bit at idle. I can drive it under the noise radar, but when I’m on it you notice me. Lots of compliments at the track on how nice it sounds especially when bouncing off a wall.
Rod
1986 Carrera
2001 996TT
Old 07-06-2025, 06:40 AM
OsoMoore's Avatar
Big surprise in the engine teardown thread - the camshaft bolt was loose! Going to see where this leads...
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1179839-1979-sc-chewed-valve-total-rebuild-2.html#post12493691
Old 07-07-2025, 06:55 AM
OsoMoore's Avatar
I think I may have located the instigating failure. The rocker shaft on the valve rocker that failed was far far out of alignment.
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1179839-1979-sc-chewed-valve-total-rebuild-3.html#post12494493
Old 07-08-2025, 12:26 PM
Thanks for that.
I must be getting old... looking for something quieter these days
Always learning.
Old 07-08-2025, 04:41 PM
Tags
911sc , rebuild
