What is this vac device
On left side of engine by WUR. Just busted it open trying to get my new fuel accumulator installed. Can it be repaired?
Thanks ![]() Sent from my iPhone using Tapatalk
1987 Marine Blue 930 1982 911SC White Plains, NY |
I figured out the part but don’t see how it would go back together (reliably).
O-ring Thin Circular spring washer around circumference Flat metal plate Stepped metal plate with step oriented towards electrical connector |
Order of assembly: https://forums.pelicanparts.com/porsche-911-technical-forum/1169023-911-sc-thermo-valve-falls-apart.html#post12342540
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
