Are These Chain Tensioners Useless?
Someone sent me an engine to put together... he bought it as supposedly complete but fully disassembled....
The chain tensioners are missing the little cap.. first pic shows the ones I received... Second pic is a spare tensioner I have that shows the cap. Am I looking to buy new tensioners because of this? ![]()
Always learning. www.aircooledporsches.com.au |
Mike, Just to make it safe, replace the two, expensive but it’s your labor if you need to replace after the build.
Bruce |
there is a guy in France who posted this video how to rebuild them and replace the nipple with bleeder screw.I am about to do some of them (i have like 6 pieces) so i will see ,when i get to it...how it works.Seams doable
https://www.youtube.com/watch?v=PtutSc_sJUo Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Wow. I just watched the video and it looks like an ingenious solution. Luckily my tensioners are fine, but I like his idea.
I think I will have to recommend my client buy 2 new tensioners to be safe.
When you get the new ones, you can install a stainless wire accross the top to keep the bleed nipple in place, just in case, as they pop out pretty easily. I also use the Jerry Woods mod and prefill the tensioner with a syringe.
1978 Targa - 1980 3.0; Carrera intake; Megasquirt 2; EDIS ignition; 22/28 mm torsion bars and late Carrera sway bars; Carrera front brakes. Targa top rebuild in 2017. Suspension rebuild in 2019. Needs new paint and interior carpets. Last edited by Marwil; 07-17-2025 at 06:49 AM.. |
Marwil..interesting, on your pic the c clip on top of the pin is removed --the reason? To fill it up..?
Ivan
I took 3 of mine apart today (my top nipples are ok) .Remove the bottom c clip and removed the plug and the pin .Filled with oil a put together...i will test it when i get a chance .....
Also i took one apart from the top cleaned filled with oil ..put together ...after i took one good one i have and test it compare the others, it did same resistance when compressed.... Ivan
One other part that is important for these to work correctly. The top of the piston has to be able to bleed out air. You will notice that the cap is pressed into the piston. The cap can be pressed out. It has threads for air to escape and a small vent at the top (circled in red).
![]() If the threads have filled with gunk over time there will be no way for the air to blead out the top and the tensioner and it will be soft. You can knock the cap out from the inside, clean the threads and press it back into the piston. john |
thanx Ivan
You can also consider these as well.
https://www.joeanselmomotorsports.com/products/sebro-chain-tensioner-fix-it-kit-911-65-83-early-style?_pos=1&_sid=9008bfdf2&_ss=r |
maybe a good solution for Mike..for me,i just wonder.. thanx Ivan
thanx for the info Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 07-20-2025 at 01:43 PM.. |
Sorry, been involved with my garage build. Due to the Jerry Woods mod the pin can't be inserted. The mod involves inserting a small section of pipe into the piston cylinder to limit the compression of the piston in case of tensioner failure. The pipe/bushing prevents the piston from compressing fully and therefor prevents insertion of the pin.
1978 Targa - 1980 3.0; Carrera intake; Megasquirt 2; EDIS ignition; 22/28 mm torsion bars and late Carrera sway bars; Carrera front brakes. Targa top rebuild in 2017. Suspension rebuild in 2019. Needs new paint and interior carpets. |
