Barn find 1978 911SC
Hey guys,
I’ve owned and maintained a 1971 911T for 25 years and finally got my 2nd Porsche ever. It’s a barn find 1978 911SC Targa, found in Denmark but from Hollywood and Malibu. It’s still got blue plates (like my 71 had). She’s got 200k miles and is rough in spots. Bones are good though. All she needs is a rebuild, interior, paint, brakes, suspension and wiring. 🙂. I was told no paperwork and show up to find window sticker and all paperwork. No sign of a rebuild though. She ended up in a Danish barn via a family friend. Motor is correct year. She is a 1 of 1 factory color for her make, model and year. Best I can tell is 10 Porsches were painted this unknown paint color : paint to sample: 358-9-3. She was repainted horribly to Hellblau metallic at the end. Brakes are not frozen! We are stoked!! Already changed all fluids and replaced perforated tank. Next up is swapping all fuel lines, new fuel pump, fuel filter, adjusting valves, replacing valve covers and getting her running for a quick inspection. Then the real fun begins. Please share your experience.
R Gruppe #514
Old 08-20-2025, 09:27 AM
Congratulations. Rebuliding it will be the best time ever, especially when it starts and drives.
Old 08-20-2025, 09:45 AM
Good thing you got your dad there to help you. Don't sit on the car.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 08-20-2025, 09:53 AM
winter
Winter's Avatar
Score!
Tom
'76 Targa
Old 08-20-2025, 01:04 PM
Very nice… any idea when it ran last?
Old 08-20-2025, 01:50 PM
Curious what order I should go in order to start this old girl?
R Gruppe #514
Old 08-20-2025, 02:03 PM
Mark Salvetti's Avatar
Congrats on the new car! I see you already found the 358-9-3 paint code thread.
Even after replacing the fuel lines, you've still got to worry about the fuel distributor. I think once you get some fuel in the tank, pull the red fuel pump relay and jumper terminals 30 and 87a. With the ignition on, this will run the fuel pump. It should circulate fuel from the tank to the fuel distributor, and then back to the tank. Hopefully this will clean out any sticky deposits. Then pull the six injectors, put them in jars, and with the fuel pump running, slowly lift up on the sensor plate inside the air box. That should let fuel to the injectors, and you can see if they are all flowing and hopefully nicely atomized.
If the distributor is messed up, you may find the sensor plate is not moving freely and/or all the injectors are not flowing. Maybe let things sit with the fresh fuel for a couple days and try again. If that doesn't work, you'll have to rebuild the fuel distributor.
Mark
1979 911SC Targa
Old 08-20-2025, 03:47 PM
I just did this on my 1978 that had been sitting since 2014. As Mark mentions, the fuel distributor will be a problem, the needle on mine wasn't moving. When you replaced the tank did you verify the lines are clear, my return line was plugged up.
To remove variables I removed my CIS components and sent them out for rebuild with Tony. Replaced the ignition components and rebuilt the distributor while I waited. Plenty of jobs to tackle on these.
-Kelly
Old 08-21-2025, 11:41 AM
PCA Member since 1988
In addition to Mark's and Kelly's comments, when you put fresh fuel in the tank, add a bottle of Chevron Techron Concentrate, or similar fuel system cleaner. You already changed the oil right? Save the old filter and cut it open to see if any metal is inside. There's a reason it was parked in a barn for years--it might have engine problems. Definitely replace all the rubber fuel lines, but the black plastic fuel injector lines on the engine should be okay.
If no metal in the filter, then remove the spark plugs and unplug the CDI. Crank the engine until you get oil pressure for 5 seconds or more. Then reconnect the CDI and check for spark. Then reinstall the spark plugs.
At this point, you can try to start it. It will probably take a squirt of starting spray to get it going.
Once you get it running, drive it! That will not only keep you motivated, it will circulate the fresh fuel and cleaner, and as you exercise the engine it will gradually run better. You will also find out what else needs work, such as: transmission shifter bushings, pedal cluster bushings, clutch adjustment, steering wheel bearings, alignment, suspension, etc.
I look forward to seeing your progress. It will be a fun father-son project. As Shane said, it's good to have adult supervision!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-21-2025, 12:02 PM
I told him to, he pushed back and I said go ahead son, it's ok.
REVerend Very nice… any idea when it ran last?
I think my father in law's best friend brough it over around 2000. He would start it and run it around a few times but not since 2005 or so.
Rather than test the injectors, I'm just going to replace them. There are 2 rebuild kits for FD and WUR that I'm sure I will have to tackle. The return line looked full of goo so no attempt at starting until I replace all the lines.
Thankfully the engine spins freely. I am quite sure it will need a rebuild though. My goal is to get it running and see why it was parked.
My turbo valve covers showed up so I can swap those in with new gaskets (should have done that during the oil change). They will replace the old likely warped valve covers on their now
Then do a valve adjustment.
Then swap the wires and plugs. (already replaced air filter, cap and rotor)
I have a fuel filter to replace
Remove all the old AC equpment. Try to sell.
Sell the BBS wheels
R&R Fuel Lines
Install new gas tank
install new injectors
take the advice above on start up process.
Which spark plugs do you recommend?
The factory suggests 10w60 for oil so may go with that.
should I rehab the old injectors or just replace, it is like the same cost?
while i wait for stuff I can adjust & pack the wheel bearings with new grease. I can also swap discs, soft lines and pads.
A lot of work was done on the 915 back in the day so that is a plus. LIkely needs new clutch, machined fly wheel.
R Gruppe #514
Old 08-22-2025, 12:10 PM
winter
Winter's Avatar
I have not done this, so I am not speaking from personal experience, but it has been reported on this forum that one can jack up one side of the car to change out (respectively) the L or R valve cover.
Or you can do what I have done, just drain the oil from the engine alone (sump plug only) into a clean container and then reuse the oil.
Good luck with the car, looks like a fun project.
Tom
'76 Targa
Old 08-22-2025, 01:39 PM
A930Rocket's Avatar
At first, I thought it looked like my Iris blue 911.
Old 08-22-2025, 02:33 PM
Amazing project, good luck and great that you are restoring it up instead of it rotting away!
Old 08-25-2025, 10:04 PM
Long , exciting road ahead to get it where you need it to be. Lots of luck , we are watching and pulling for you !!
Old 08-26-2025, 01:26 AM
H-viken's Avatar
Awesome James, what a cool project!
Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 08-26-2025, 01:47 AM
buster73's Avatar
Hi James,
For a street car I would go with 20W-50 and safe the money for an extra tank of gas. What is you engine code 930/04 or 930/06 ? . Hopefully we will have plenty of time to discuss your project when we meet for "Eurotreffen" in September
Regards,
Guenter
73.5 911T, mod
Old 08-26-2025, 05:09 AM
Been busy and slowly moving forward. Sold the BBS wheels and bought some parts.
Removed the heavy AC compressor and giant condenser. Removing the rivets that held in the condenser was a challenge and I kept breaking drill bits.
Started the valve adjustment and removed 20 year old spark plugs
Then I found 4 broken swivel feet when I took the exhaust valve covers off. Ooof. I’m going to pivot to CIS system, brakes, suspension and then take the motor to get rebuilt and take body to get paint.
R Gruppe #514
Old 09-14-2025, 12:46 AM
Here is one broken one and what engine looks like without compressor
R Gruppe #514
Old 09-14-2025, 12:48 AM
winter
Winter's Avatar
I guess you’ve discovered why it was parked!
Tom
'76 Targa
Old 09-14-2025, 04:21 AM
Sweet find, I am going to follow this build.
I rebuilt the fuel distributor in my 930 barn find.
The center piston was completely stuck, I had to split the upper half from the lower and then hammer the piston out. But if your careful,. and keep track of all the little parts it's not that hard to rebuild. This is a good excuse to get an ultrasonic cleaner.
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/848849-barn-find-1986-911-turbo-11.html
I have not done the warm up regulator yet, but there are plenty of videos on YouTube.
Performance EngiNerding
Old 09-14-2025, 05:53 AM
