(man/dude)
"My measurements and calculations tell me if I was to remove the roof skin from a non-sunroof car, that piece of steel would weigh 13.5 pounds, so about double that of the carbon skin." I would never cut a steel roof off a non-sunroof car and replace it with carbon, the weight difference simply isn't worth it if you are starting with a NON-SUNROOF car. I do plan to make a slightly lighter skin. It probably doesn't NEED to be strong enough to stand on LOL. The lighter skin should be in the range of 4-1/2 pounds, and bring the weight delta to a steel skin to the 9 pounds you suggest. The real advantage of the carbon roof would be the weight savings combined with the lower cost of the part, ease of shipping, and ease of installation/less labor cost.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
This week's update. The roof is painted. At the front the roof is painted all the way down the cowl sheet metal/wiper section to where the plastic seals are at the front fenders, so there is no paint blending or transitions to worry about, and at the rear, C pillars, the paint perfectly blends to the existing. Around the door frame and rear windows, the paint is continuous around and under the gutters, which will be covered with new rear window seals and the new headliner/existing door gasket.
![]() ![]() ![]() ![]() And a new headliner ready for installation: ![]() And two layers of Siless 1/4" closed cell foam lined along the inner roof for sound absorption and some thermal insulation. The gaps between panels are for the clearance of the steel headliner rods, which on install, rest tight against the roof. ![]()
Nice!
Steve…..looking great. I bet you can’t wait to get her back!
Have whoever does your windshield give us a blow by blow of how he gets the trim shaped so there is no leakage. Lots of recent threads of people struggling with that.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
At 6'4", I would love to have this done. My issue is I'm the original owner of a 1983 sunroof car. The only type that was available in April 1983. This car was what I wanted once I saw Le Mans in 1971 with Steve driving his 911 through the outskirts of Le Mans. Just can't bring myself to either sell and locate a non-sunroof car or chop mine up. After 42 years, it has become part of me, I guess. The sober part. . .
Don Newton “People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.” "I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams |
Although if I wanted to install the original type windshield for a G-body, we had a discussion about that and he did say regarding the rubber seals, they all fit different (factory Porsche, German made, URO, etc.) and the only one he trusts and uses is the German made from a supplier such as SSF. In any case, when the windshield is installed, I'll upload pics. Last edited by Steve W; 09-18-2025 at 07:29 PM.. |
