red fuel pump relays
More active in LWB 911. Not really bumper models.
I have several red fuel pump relays lying around here. Two have the part number 911 615 108 00 and three have the part number 911 615 108 01. I'm hoping the CIS gurus here can help. When was each one of the two relays used? |
The index 00 & 01 has no meaning for customers, it's an internal index from Porsche indicating a different vendor or manufacturer. You can use the red ones anywhere in the car, the black ones only where they are allowed... Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 12-05-2025 at 07:10 AM.. |
Jason |
Thanks for your input, Schulisco.
My question is more or less anorak: When was index 00 used and when superseded by 01. |
75+ used 911 615 108 01: https://911-manuals.questionable.services/porsche-pet-911-mid-year.pdf
I don’t have a 73.5-74 PET but thus presume the -00 relay applied to those early CIS cars. The 74-77 PET doesn’t mention it. 74-77 PET denotes 75+
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
red relay with 00 on end got changed to 01 , that is all....always made by Wehrle company
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Hi Ivan, yes just changed 00 to 01, same company.
Hi Silverlock, your reference is the 2010 dated PET.pdf? |
Yes, the one I linked. The PETs had corrections made to them over the years.
I have the PET catalog for 73 and it doesn't refer to this relay type number at all.
The standard round relay referred to is 911 615 109 01.
Gilles RoW 88 Carrera coupé |
Again - the index doesn't matter technically at all! So you can use them anywhere in all 911's using them.
Currently Porsche lists the red relays with index 02 ...
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Red FP Relays………
Got too many red relays laying around and made use of them.
![]() Tony |
PCA Member since 1988
You just wanted the to match the paint.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Can someone with the not matching red burgundy 75-77 spare parts folder or microfiche chime in?
