Question Oil Tank Identification
I would appreciate some help identifying these oil tanks. I've done quite a bit of research and have labeled my educated guesses. Can anyone confirm or correct?
I am working on an engine test stand and will pick one to use for that. I am thinking the one bottom left is the best candidate. It appears to be the least valuable, has fewer ports to deal with than the one bottom right, and a couple mounting points built in.
Thanks.
Old 09-06-2025, 08:52 AM
E Sully's Avatar
Go to posts 6 and 13. The bottom right would have least value to collectors.
https://forums.pelicanparts.com/porsche-911-technical-forum/1124699-sc-vs-carrera-oil-tank-differences.html
Ed
1973.5 T
Old 09-06-2025, 11:22 AM
Thanks for that link. It is helpful. I'm still not clear on the part number. The PDF catalog for 74-78 and 78-83 list a few with the same drawing but don't differentiate them:
930 107 006 00
930 107 006 03
930 107 006 04
930 107 006 07
I think the two additional ports are an indication this was meant for Sportmatic.
Old 09-06-2025, 04:20 PM
The one lower left, labeled 73-77 is a 73 one year only.
Old 09-06-2025, 05:47 PM
E Sully's Avatar
Not Sportmatic. It is from the '80's and probably for the 930 Turbo models.
Ed
1973.5 T
Old 09-07-2025, 12:47 PM
E Sully's Avatar
Screenshot of a 1986 Slantnose 930 oil tank.
Ed
1973.5 T
Old 09-07-2025, 01:57 PM
Tags
engine stand , engine test stand , oil tank
