I'll say it again, that engine and transmission mounts are an extremely overlooked part of proper alignment of the drivetrain in relation to the shift linkage. If they are over 10 years old, chances are they are worn out beyond usefulness. My 1982 mounts were original and sagged so badly that the transmission shift snout was nearly resting at the bottom on the bulkhead shift rod tube.
This https://www.redlineoil.com/75w90-ns-gl-5-gear-oil oil is amazing and actually makes shifting so much better in my toyota and porsche compared to cheaper oils. |
Still here
Of course. |
Hi,
I had the 915 factory short shift kit installed, went then to the Rennline exactshift billet short shifter… wasn’t happy with this one and replaced it by the CAE shifter. Quality and function are superb… Nothing beats German engineering. Cheers |
I'm happy with my Numeric. It fits fine with the stock rubber and console as well. I much prefer the self-centring function and it comes with the solid coupler as part of the purchase.
1978 911SC with Lobster Interior - Zoidberg http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html |
Insert Tag Line HERE.....
WEVO.. by far... with the PSJ shift coupler. Totally transforms the car...
Marc |
Full Send Society
After my 915 was rebuilt this winter it’s as nice of a transmission as I’ve ever experienced. No lag in 1st to 2nd, no slipping, grinding, pausing, forcing, sweet talking or cursing.
The change from prior to the rebuild was night and day. We just did the tail of the dragon yesterday en route to Overcrest, and I didn’t even think about my shifting at all- it just did what I wanted; rowing through the gears as the car slalomed through the switchbacks. When properly sorted, the 915 is a perfectly wonderful transmission. All of the aftermarket products are bandaids (of varying degrees of utility, performance and hype) until the internals are addressed. Stock shifter, karsten spring, new bushings, Novak tunnel bushing, wavetrac LSD, taller 5th…otherwise stock Sent from my iPhone using Tapatalk
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Thanks for all the feedback, I ended you going with the JWest and I love it!
