-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Firewall insulation (http://forums.pelicanparts.com/showthread.php?t=1185166)
thsupernge 10-19-2025 03:25 PM
Firewall insulation
What have folks found for replacement firewall insulation? I was thinking about replacing while I was back there...lots of crumbling coming off of mine.
Thanks in advance.
Tom_in_NH 10-19-2025 05:43 PM
I'm pretty sure Daniel (dg567) makes and sells a high quality engine compartment insulation pad.
Louisieg55 10-19-2025 07:28 PM
You cam. Buy them pre cut fro, the host for a decent price and they are cut to size
thsupernge 10-20-2025 08:24 AM
cool, thanks. just wondering what people have found...
RSTarga 10-20-2025 02:01 PM
the originals are a fire hazard get one of the aluminised ones.
Winter 10-20-2025 02:36 PM
Saw this product used on someone’s build thread.
Product looked great installed. I made a note of it, but haven’t done an install yet so can’t comment on performance yet.
https://www.classicvwbugs.com/product/classic-porsche-deluxe-engine-sound-insulation-tar-boards-911-912-1965-1989/
thsupernge 10-20-2025 03:26 PM
Do you have a link by chance?
thsupernge 10-20-2025 03:28 PM
Appreciate it, I will take a look!
ben parrish 10-20-2025 03:31 PM
That looks great.
EC900 10-20-2025 06:13 PM
The old vinyl and foam was intended as a sound deadener. Mine crumbled away and bits of rubber were all over - shroud, airbox, even burning on the heat exchangers. So here’s some tips on removing it….
Cover the engine with a sheet or tarp and then pull away the old stuff in large chunks. Use a plastic putty knife to reach the back areas for the cling ons.
Shop vac the small stuff you can see.
Compressed air the leftover bits. It’s going to drop on trans and HE’s so be thorough and Do this outdoors. That old dried foam is like thick dust.
Vac again, blow out again. I still found/find the old foam all over 3 yrs later.
You see how much glue residue remains, that could be tedious and timely to clean.
I was going to use the aluminum foil self-adhesive Heat/sound stuff on the interior but without that old vinyl, I did not find the cabin any noisier or any bit warmer.
But these barriers have good claims. Will maybe do engine bay if ever I drop it.
thsupernge 10-20-2025 08:10 PM
This is great, thanks!
