Firewall insulation
What have folks found for replacement firewall insulation? I was thinking about replacing while I was back there...lots of crumbling coming off of mine.
Thanks in advance.
Old 10-19-2025, 03:25 PM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
I'm pretty sure Daniel (dg567) makes and sells a high quality engine compartment insulation pad.
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 10-19-2025, 05:43 PM
You cam. Buy them pre cut fro, the host for a decent price and they are cut to size
Old 10-19-2025, 07:28 PM
cool, thanks. just wondering what people have found...
Old 10-20-2025, 08:24 AM
the originals are a fire hazard get one of the aluminised ones.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-20-2025, 02:01 PM
winter
Winter's Avatar
Saw this product used on someone’s build thread.
Product looked great installed. I made a note of it, but haven’t done an install yet so can’t comment on performance yet.
https://www.classicvwbugs.com/product/classic-porsche-deluxe-engine-sound-insulation-tar-boards-911-912-1965-1989/
Tom
'76 Targa
Old 10-20-2025, 02:36 PM
Do you have a link by chance?
Old 10-20-2025, 03:26 PM
Appreciate it, I will take a look!
Old 10-20-2025, 03:28 PM
That looks great.
1986 3.2 Carrera
Old 10-20-2025, 03:31 PM
The old vinyl and foam was intended as a sound deadener. Mine crumbled away and bits of rubber were all over - shroud, airbox, even burning on the heat exchangers. So here’s some tips on removing it….
Cover the engine with a sheet or tarp and then pull away the old stuff in large chunks. Use a plastic putty knife to reach the back areas for the cling ons.
Shop vac the small stuff you can see.
Compressed air the leftover bits. It’s going to drop on trans and HE’s so be thorough and Do this outdoors. That old dried foam is like thick dust.
Vac again, blow out again. I still found/find the old foam all over 3 yrs later.
You see how much glue residue remains, that could be tedious and timely to clean.
I was going to use the aluminum foil self-adhesive Heat/sound stuff on the interior but without that old vinyl, I did not find the cabin any noisier or any bit warmer.
But these barriers have good claims. Will maybe do engine bay if ever I drop it.
Old 10-20-2025, 06:13 PM
This is great, thanks!
Old 10-20-2025, 08:10 PM
