Replacing engine fuel line rabbit hole.
While replacing the engine fuel lines without dropping the motor, I want to address everything that sits above the long block. I bought the car 5 years ago with no maintenance history. I have done a valve adjustment right after purchase which was maybe 1,000 miles ago. The car in question 1987 Carrera with 88,800 miles.
Before ordering parts, is there anything that I'm missing "while I'm in there"?
Here's the list:
I have the rear man seal just in case I decide to drop the motor. If that does happen, I'll order a clutch kit as well.
Am I missing anything? Help is appreciated.
Current state of the vehicle
Thanks for viewing.
Old 11-04-2025, 12:21 PM
All the little vacuum tees and elbows are probably gummy and need replaced, along with throttle plate o ring. I found doing the same on my 85 it helps to have the car on ramps or a lift to save your back from stooping.
Old 11-04-2025, 12:44 PM
Throttle o-ring is definitely on the list. Great tip on the vacuum lines. I'll see if I can get some new ones in my cart. Thank you.
Old 11-04-2025, 12:56 PM
A big shout out to our fuel line re-hosing expert Len Cummings! The turn around time was rather impressive. Sending a money order was a non-issue since I was going to the post office to drop off the package anyways. Thank you.
Also, another quick turn around (but not as quick as Len's service). RC Fuel injection gave the injectors a new life. I'm surprised with only 88k miles, the injectors were performing pretty poorly.
Since half of the injectors were dripping, I wonder if i had an issue with one side of the fuel injector rail.
Old 11-06-2025, 10:49 AM
It’s the California fuel; it has too much ethanol in it, and if you let your car sit for a period of time, the injectors get gummy.
Old 11-06-2025, 03:37 PM
Are there any additives that we can add to prevent fuel injectors gumming up? I know that's its own topic, but it's something I need to look into. Thanks for the tip.
I drop off a few bits nearby to get plated and just under 48 hours, I get a text at 7am telling me to come in before noon. This is about all the hardware you would find that sits on top of the long block.
Here's a before photo
Old 11-07-2025, 10:34 AM
Wow you're fortunate to have such a plater nearby
Porsche recommended adding techron for cis systems, id run techron or just fill up at chevron a dose of seafoam fron time to time
Instagram.com/timofthevalley
Old 11-07-2025, 10:46 AM
In addition to the vacuum lines (some Conti/OE-look from HPS does well), also look at the TB/AFM boot as well. Cracks develop as it ages out.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 11-07-2025, 12:09 PM
356 guy
Please share how much it cost to have your plating done for those parts.
It could help us determine if our local shops are charging fairly.
I wonder if your guys do mail in and out service.
John
Old 11-07-2025, 01:09 PM
I really am. Ironically, there are two next door to each other. I drove to the plater shop without using my GPS because I "knew" the area quite well. I mistaken drove past by the place that I was SUPPOSED to go and walked into the neighboring business. I'm not disappointed, but it was eye watering expensive.
See the cost below.
My vacuum lines are not too far off from new condition. I needed a a flat bladed driver to undo the lines to the FPR and damper. TB/AFM boot in fantastic shape without any cracks.
I'll revisit the conditions once I get everything. Great suggestion.
John
I lost my appetite after hearing their quote but I had it done. It was $500. Mind you that I'm in California and It was about 2 miles away from me. California has up the environmental fees.
Old 11-07-2025, 01:31 PM
Targa_PB_78_SC
mike sampsel's Avatar
Be sure to not let your gas sit for more than 6 months (dive it enough to get fresh) add a can of seam foam for every 16 gallons you add. With seaFoam and or stabil fuel freshener they claim two years of freshness, so 6 months should be great.
I can only get ethanol fuel, and following this method I've had no issues. On one of my cars I drain the tank every year and put the old gas in the daily driver, the drain car does not often see enough miles to use up the gas.
BareRearedRookie
Old 11-07-2025, 02:21 PM
PCA Member since 1988
FYI, "Project Farm" recently finished a long term test of fuel stabilizers. Stabil brand was the clear winner in preventing metal corrosion inside the fuel system. However, none of the tested stabilizers did well at preserving or stabilizing the fuel.
One more time: The best thing you can do to prevent fuel problems is to drive it regularly and put fresh fuel in it. If you know it will be parked for long periods, then try like hell to find pure gas and fill the tank with that. Otherwise, drain the fuel.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-08-2025, 11:24 PM
I'll siphon as much as I can to have more control of the fumes. Our garage is attached to our main living area and draining the tank would not be good for the family. But I fully understand your point.
Silly question. How about I fill up with the tank with a few gallons at a time? Would that be more beneficial?
"Drive your car" is so much easier than it sounds!
I would if I could. But for some reason I can find 50 hours to do this fuel line job.
I appreciate the PF suggestion, I'll give that a look. Thank you.
When replacing the air filter a few years ago, I couldn't get the rear bottom air box latch to latch. I tried a bit too hard and well, it broke. Since the whole manifold is out, I've been trying to come up with a way to repair the tab on the air box, and here it is.
I found a washer that matched the size of the crevice, stuck it in a vice and hammered it in to a U shape. I sanded the box and the washer with 80 grit and applied JB Weld. I allowed it to cure over and night and these are the results.
Last one. Can I cut off the end of this cruise control cable to get the bracket replated? Or would it be too short if I were to put a new crimp on it?
Old 11-13-2025, 10:47 AM
Amazing refurbished fan+housing from FlyingJay.
Old 12-19-2025, 11:17 PM
Mark Salvetti's Avatar
No, I think that would actually be detrimental. The tank "breathes" with temperature changes. You want to minimize the air space in the tank, as the humidity in the air can add moisture to the fuel, especially with the ethanol.
I would use Marine Stabil regularly, and top up the tank before winter storage. You should be fine. Then add fresh fuel in the spring once you get down to about 1/2 tank. If you are really concerned, siphon out half the tank when you take it out of storage, put that in your daily driver, then fill with fresh. But I think that is overkill.
What is FlyingJay's turnaround time for the fan refurb? I want to do that.....
Mark
1979 911SC Targa
Old 12-20-2025, 05:55 AM
Mark
I greatly appreciate the insight. Siphoning isn't a problem as I have become an expert on it upon the car's arrival. It isn't difficult and it's much less work than draining the tank from the bottom and catching it in a pan then transferring to a jug... andwell you get a idea.
FlyingJay's turnaround time was just about 2.5 months. I highly recommend him if you can afford the down time.
Old 12-20-2025, 11:21 PM
Nice project to address leaks, or stay ahead of them. And the finished project will be pure eye candy to those of us with this affliction (addiction?) !
Glad to see FlyingJ still turning out beautiful work. He cerakoted and plated my fan assembly a couple of years ago and it still looks perfect. His turn around time can vary, but he returned my finished goods quicker than expected. And Len’s hose & plumbing work is also top notch!
Please keep this thread going so we can see the results. Patrick
912E-3.2ss
Old 12-21-2025, 12:34 AM
Just another idea to throw out there for dealing with busted lips on the airbox... bits of steel/brass/aluminum can be bent in a vise, then some aircraft metal lock nuts & screws to keep it secure. If you'
re really concerned about the engine ingesting hardware, then get drilled bolts with castellated nuts and use cotter pins. The metal locknuts in the pic will never move though- they have a relatively high prevailing torque.
Nice project you have- so many little things to fix. Going through this right now with mine.
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 12-21-2025, 10:05 AM
A930Rocket's Avatar
Looks beautiful.
I need to get mine done.
Old 12-21-2025, 05:34 PM
'87 Targa
Dave, I really like your airbox clip fix. I have one that is cracked and needs attention.
I may copy you, and try pop-rivets to secure it. Maybe?
Old 12-21-2025, 08:18 PM
