Well, I guess this is yet another oil thread...
I have some remnants of a case of the Kendal NS-MP and have been casually looking for a replacement for when that's gone. I'm a LiquiMoly fan; their oil-finder database points toward this stuff (mineral-oil GL5): https://www.liqui-moly.com/en/us/hypoid-gear-oil-gl5-sae-85w-90-p000216.html#tab-label-approvalsandspecifications-title I haven't tried it yet. I have compared this to the Shell Spirax MB90 and all the tech specs are very, very close. Here are the tech data sheets for both: https://pim.liqui-moly.de/pdf/en_US/liqui/51/P000216 https://www.shell-livedocs.com/data/published/de-AT/d8eb48c9-0b91-4b59-89b9-76903279f133.pdf Swepco 201 datasheet for reference: https://swepcolube.com/wp-content/uploads/2024/07/SWEPCO-201-Multi-Purpose-Gear-Lube.pdf I have tried finding a TDS for the Super Tech 80w90 and haven't located one. |
In 1973, it was a 915. 901's (with the cool dogleg) were last installed in 911's in 1971.
'80 SC Targa Avondale, Chicago, IL |
gearhead
Feeling better doesn't mean anything with respect to wear. Above when I mention that I only put my racing customers in Swepco it's because it shifts poorly when cold. When hot during racing, it better protects from wear, and doesn't shift the same as it does on the street where 2/3 of people don't even drive the car long enough to get the gearbox up to full temp. I remember there was a time where everyone and their mother was putting Redline into their Porsche gearboxes. You'd see people raving about how good they shifted. On the service side of things, we saw what they looked like inside and they were getting shredded.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Administrator
Matt what gear oil do you recommend for a street-driven early car with a non-LSD 911 (or 901, as they are also called) gearbox?
“Same as I’ve said for a long time. Walmart Supertech 80w90 conventional gear oil in the blue jug. It’s made by Mobil. Valvoline and Catsrol also both have conventional oils still. I recommend Swepco to my racing customers. But I don’t drive it on the street. For a few years I’ve been posting about the changes to that NS Kendall gear oil. I think it was Phillips who bought them? It changed to semi-synthetic a year or two later. I hadn’t heard it was discontinued, but it might be.”
Rutager West 1977 911S Targa Chocolate Brown |
I just went to both Castrol’s and Valvoline’s websites and neither had a recommended gear oil for our earlier 911s. If memory serves, the earliest gearbox listed was 1997.
gearhead
This is the Valvoline I was thinking of.
https://shop.valvolineglobal.com/collections/conventional-gear-oil?srsltid=AfmBOop-C50ii8TnVytjatSERX4XHqNXlyvq5V3w1p9o1XI5N1_ndH4w
gearhead
And this is the castrol.
https://www.oreillyauto.com/detail/c/castrol/castrol-conventional-gear-oil-80w-90-1-quart/cas0/8090?srsltid=AfmBOors0Plczpwi_16CWy1L4UZIcSeO4sxcE R_nWZ11ugnmuQbe5QZW
Powersports/motorcycles have similar gear oil requirements and the industry is a good source for trans oils. They are non synchronized (no brass, dog gear synced), have a bevel (straight cut as well) gear primary drive similar to a ring and pinion. And depending on which oil, designed for wet multi plate clutch packs.
I have been using Bel Ray gear saver motorcycle oil in my 915. GL-5, non synthetic, 80w90. Not for wet clutch. https://www.belray.com/product/gear-saver-hypoid-gear-oil/ Easily available from any motorcycle shop and usually on the shelf, but here is a link to amazon for easy lookup. https://a.co/d/4dE95bb These non synthetic options I have not tried personally but would be options for LSD 915s. 80w85 Thumper trans oil that is designed for competition dirtbikes with wet multiplate clutches. https://www.belray.com/product/thumper-gear-saver-transmission-oil/ And they also have a trans oil that is straight 85w (listed on SDS) called Sport transmission fluid that is also designed for wet multiplate clutches. https://www.belray.com/product/sport-transmission-fluid/ All of these oils are designed for extreme shock and gear load. ![]() Sent from my SM-F741U using Tapatalk
Standard Competition Motors, Berkeley Heights, NJ | Maxxecu engine management and Plex tuning calibration specialist and supplier | chassis dyno tuning and calibration consultations http://www.instagram.com/standard_competition_motors |
gearhead
Sorry, I didn’t drill down all the way in the description. But as you found the sand oil is available non-lsd as well.
Odd how no one wants to buy the Porsche official oil.
https://www.pelicanparts.com/More_Info/PELTFLUIDKIT911.htm?pn=PEL-TFLUIDKIT-911&srsltid=AfmBOor-Y2_A65yNX_EsCrchuQlRr1ICZlcwaBs2N9DPxJCOWll3bY2u Only 200$! And includes new plugs!! Last edited by 917_Langheck; 12-23-2025 at 07:34 PM.. |
Otter74, I wouldn't do that. Any oil has its own purpose. Motorcycle oils have different duties than car oils. They have to deal with wet clutches which most cars won't have (aside of double clutched car gearboxes). Mostly gear and engine oil on a motorcycle are in the same housing. Okay that Bel Ray is a transmission oil only. But still - I wouldn't use it in a car gearbox.
Here's a video talking about engine oils and crossed usage in cars&motorcycles. I expect the same for transmission oils: https://youtu.be/1DxZq7ISeSE Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 12-24-2025 at 01:40 AM.. |
Apples and oranges, Thomas. The video is referring to engine oils and makes a few valid points. However, our 911 gearboxes have more in common with a v-twin Harley than they do a new 911.
Bel Ray's GL5 rated hypoid gear oil (85w140) has stood up to the extreme conditions we've put it though with no adverse affects to the internals. Sure it takes a minute to warm up and will shift a little clunky until then, but you're waiting for the engine oil to warm before attacking the far side of the tachometer anyway. Once everything is up to temp you can beat it like a rented mule knowing your gearbox is protected. Also, these aren't lifetime fill or even a G50 with longer fluid intervals. I recommend changing it at least every 15k miles. Bel Ray is inexpensive - I swap it out after every rally (typically 5k miles). Total cost for bearings for a 915 are well over $1k now, what's an extra $40 for gear oil. I don't have skin in the game - I build 915s for fun to support fellow rally dorks. Y'all do whatever you want. I'm just sharing my experiences.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
gearhead
I’d use the motorcycle oil suggested in my gearbox.
I had my 915 rebuilt at California Motorsports last year. They mandate Swepco 201 80w-90 only for transmissions they rebuild.
https://www.pelicanparts.com/More_Info/SWE20180W90.htm?pn=SWE-201-80W90 They also require transmission fluid changes every 10k miles. Last edited by ErrorMargin; 12-24-2025 at 05:26 PM.. |
Racer
Swepco 210....it works better in the cold and the hot compared to 201...
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
