https://www.youtube.com/watch?v=ynJhhmi4TCM Quote:
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 12-23-2025 at 04:48 PM.. |
PCA Member since 1988
Every time I go to Chinazon, I get different prices and brands, but most of them obviously are the same kit, just different names. Look closely at the pictures, and you will see that the kit has a T and valve, with hoses on each end, located at the bottom of the upper cover. That's the piece you want. Search for this string of words: Pro Master Fuel Injection Pressure Tester Kit - Perform Fuel Pressure Testing, Diagnose Weak Fuel Pumps, Test Fuel Flow, and Leak-Down - Works on Vehicles 1997 and Newer
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 12-23-2025 at 05:51 PM.. |
Jason |
