-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   What is this reservoir in the fender? (http://forums.pelicanparts.com/showthread.php?t=1187561)
triplesn8s 12-24-2025 06:28 PM
Started dragging suff out i need to get rid of to make a little more room to work on the 72T. Do i keep this reservoir when i lose the fenders? Its rather large, but up front . Not sure what how it functions. http://forums.pelicanparts.com/uploa...1766629688.jpg
Showdown 12-24-2025 06:34 PM
Vapor/fume expansion tank. Plumbed to the fuel tank and then back to the charcoal filter in the engine bay.
I deleted mine with no adverse effects/smells though others may have different experiences.
HarryD 12-24-2025 11:05 PM
Item 2 in the first post of the thread I attached is the tank you show. The rest of thread explains the system.
https://forums.pelicanparts.com/porsche-911-technical-forum/481800-fuel-evaporation-emission-system-71-911t.html
Fixer 12-25-2025 03:21 PM
I always delete it and more importantly the heavy charcoal canister. The charcoal canister iirc has the weight of a nice size brick. Toss it on a shelf. Then find more lbs to remove.
lateapex911 12-25-2025 07:57 PM
Charcoal canisters provide important function in terms of vocs unless I’m mistaken. I take the weight in trade for cleaner air. But that’s me.
triplesn8s 12-25-2025 07:58 PM
Thanks guys. Looks like ill bin it. I cant imagine anyone would want it for an all original resto. That would be insane, right… ��
HarryD 12-25-2025 08:45 PM
FWIW, if the tank is not cracked, it is worth good money.
Also, you fo want a vapor recovery system so your garage and passenger cabin does not smell of gasoline. The thread I linked above and others discuss options to address this.
HarryD 12-25-2025 08:57 PM
A URO replacement is $92.25 and can be seen here https://www.pelicanparts.com/More_Info/91120107300.htm?pn=911-201-073-00-M253&bc=c&SVSVSI=18390#kitsComAnc
