What is this reservoir in the fender?
Started dragging suff out i need to get rid of to make a little more room to work on the 72T. Do i keep this reservoir when i lose the fenders? Its rather large, but up front . Not sure what how it functions.
Triplesn8s
'72 911T Coupe - Resto Proceeding at a Snails Pace
‘80 TR8 Convert - SOLD
'78 TR8 Coupe - Autocross Project
'06 Ducati 1000SS/DS - ‘11 H-D XR1200x
Old 12-24-2025, 06:28 PM
Full Send Society
Vapor/fume expansion tank. Plumbed to the fuel tank and then back to the charcoal filter in the engine bay.
I deleted mine with no adverse effects/smells though others may have different experiences.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 12-24-2025, 06:34 PM
HarryD's Avatar
Item 2 in the first post of the thread I attached is the tank you show. The rest of thread explains the system.
https://forums.pelicanparts.com/porsche-911-technical-forum/481800-fuel-evaporation-emission-system-71-911t.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-24-2025, 11:05 PM
Fixer's Avatar
I always delete it and more importantly the heavy charcoal canister. The charcoal canister iirc has the weight of a nice size brick. Toss it on a shelf. Then find more lbs to remove.
Old 12-25-2025, 03:21 PM
lateapex911's Avatar
Charcoal canisters provide important function in terms of vocs unless I’m mistaken. I take the weight in trade for cleaner air. But that’s me.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 12-25-2025, 07:57 PM
Thanks guys. Looks like ill bin it. I cant imagine anyone would want it for an all original resto. That would be insane, right… ��
Triplesn8s
Old 12-25-2025, 07:58 PM
HarryD's Avatar
FWIW, if the tank is not cracked, it is worth good money.
Also, you fo want a vapor recovery system so your garage and passenger cabin does not smell of gasoline. The thread I linked above and others discuss options to address this.
Harry
2020 MB E350 4Matic
Old 12-25-2025, 08:45 PM
HarryD's Avatar
A URO replacement is $92.25 and can be seen here https://www.pelicanparts.com/More_Info/91120107300.htm?pn=911-201-073-00-M253&bc=c&SVSVSI=18390#kitsComAnc
Harry
2020 MB E350 4Matic
Old 12-25-2025, 08:57 PM
