Might be on a bit tight...
Fan nut after my fifth attempt at removal. Not sure how the PO got it this tight but starting to deform the nut. I might just cut it off...
Additional ideas welcome. Someone suggested an impact but the body prevents a straight shot at it and I would think that I would have to cut the belt to prevent any backwards rotation.
Old 01-10-2026, 11:19 PM
A930Rocket's Avatar
Use a impact universal if you can’t get a direct line to it I’ve always used a impact on mine
Old 01-11-2026, 03:08 AM
Shaun @ Tru6's Avatar
I wouldn't heat the nut with a standard mapp torch, but an oxy-mapp set-up has an ultra hot micro flame that would heat it enough to turn off easily.
Tru6 Restoration & Design
Old 01-11-2026, 04:53 AM
You need a spanner wrench to hold the pulley it goes in those little holes. And a socket that fits
Old 01-11-2026, 05:50 AM
The 9 Store
Yes, impact with a universal joint. Done.
All used parts sold as is.
Old 01-11-2026, 06:41 AM
Did that on the first try, it started to bend the spanner.
Old 01-11-2026, 07:57 AM
I can try that. Do I need to remove the belt? I'm just worried about the counterotation.
Old 01-11-2026, 07:59 AM
The 9 Store
Nope - keep the belt on. It's how we do every one at the shop. Super easy and safe.
Old 01-11-2026, 10:50 AM
Still here
pmax's Avatar
Is it just me that the threads still look dry ?
Scratching my head too about how a well fitting 6 point socket messes up the nut like that ?
Old 01-11-2026, 11:55 AM
Then stand to the right and push hard with a straight arm.
206 637 4071
Old 01-11-2026, 12:40 PM
I'll juice it up again and try the impact and then the method with the spanner against the engine if that doesn't work.
Thanks guys, I appreciate the help and the patience.
Old 01-11-2026, 01:01 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
John W is always right on, go with his recommendations.
1986 Targa Guards Red
2021 MT09 SP
Old 01-11-2026, 02:32 PM
Still here
pmax's Avatar
What tools are you using ?
Old 01-11-2026, 03:24 PM
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 01-12-2026, 01:48 AM
I have tried sockets, extentions, the spanner, cheater bars, heat and a crows foot with a long extention. Most recently the allen with a crows foot on the nut.
Old 01-12-2026, 12:53 PM
Fire.
there's a chance someone put blue loctite on the shaft.
Again, I probably wouldn't use a standard mapp torch head, even at low flow, but an oxy-mapp will safely have the nut off easily in minutes.
great excuse to buy a new tool. very handy for lots of things.
Old 01-12-2026, 01:01 PM
Still here
pmax's Avatar
OK, I'm guessing it was the crowfoot slipping off making those impressions.
Nuts are cheap ... I would dremel or equivalent.
This one's a goner in any case.
Old 01-12-2026, 01:35 PM
Hi
Option one:
Follow John Walkers excellent photos.
Option two:
Drill thru the nut parallel to the alternator axis.
Open the hole with larger drill bits until it opens out the outer flat surface of the nut.
Split the nut with a cold chisel.
Undo nut.
Buy new nut and shim(s).
(Position hole so that nut and alternator threads are not drilled at final hole size.)
Cheers
Old 01-12-2026, 02:01 PM
Yeah agreed on all counts. I have a mapp torch, I will give it a shot.
I like John Ws method but just nervous about snapping the toolkit spanner with the forth this thing has been put on with...
Old 01-12-2026, 02:16 PM
If you don't want to spring for the oxy-mapp, get one of these so you can control the size of the flame better. The key is just getting the nut hot, not the shaft and alternator itself.
Old 01-12-2026, 02:28 PM
