Hi,I need some help,I am in the process in changing the front valance,It looks like I have to remove the bumper to replace the front valance.Has anyone had replace the front valance without removing the bumper.I remove the fog lights,to try to get to the bolts at each corner,cant reach it behind bumper.Please Help,any info appreciated.
Robert Parra |
Don't need to remove bumper - in fact removing valance is best first step for removing bumper. Bolts (13mm a/f and not captive) are best reached from wheel well - then release last ones inside luggage compartment - apart form access it's an easy job.
Roy
Roy |
It's easier if you jack the car up and put it on stands so you can get up close and personal with the valance
I've done it a couple of times and is a 3-4 on Wayne's 101 scale. Rick
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
There are two bolts inside the trunk in the nose of the car that need to be removed. It is a easy job except the tight fit to remove the side rubber pieces.
George My Owners Gallery Page 1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running. 1995 BMW 525I 2001 Highlander- kid mover |
Does removing the valance -as per above procedure- mean that the rubber spoiler lip (which I assume is attached to the valance only) comes off at the same time?
I assume it would then be easier to replace that rubber spoiler in one swoop, with the valance removed ? (after I've had it repainted, which would be my reason for removing the valance...)
Belgik 1988 Carrera 3.2L |
Yes, the lip is attached to the valence and comes off with it.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
valance removal
Thanks for all the info,I will try to remove the corner bolts again without removing bumper ,I will let you know if I am successfull,any more info will br appreciated,Thanks.
Robert Parra |
Hi,
Well I had to remove bumper to remove valance,on right side of valance the bolt is behind bumper bracket and oil cooler and motor,I might paint the front bumper,now that it is off,due to rock chips.
Robert Parra |
