COL 911
I can't remember if I had problems sourcing a 27mm at the time I did my install, but a relatively inexpensive 1 1/16" from the auto store works as well, and is now in my kit.
Beetle, Bimmers, Saabs, and finally...1987 Carrera |
just me
Just browsing through this thread because I'm having issues getting my turn signals to work since I installed the steering wheel. The directions are really crap! I used this thread already once to find out that about the plastic ring for the horn and turn signals, the horn works fine but the signals don't work. The only thing that works from the signals is the parking function if the ignition is off and the signal stalk is in the left or right position. so the lights are getting power but they won't flash. have I done something wrong?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Guys, I've just bought 964 C4 1992, Euro. Tutorial for Momo Prototipo installation needed! Actually I don't know what to do with airbag wires... Thanks in advance.
CarBone. We make cool stuff for aircooled enthusiasts. www.carbone.pl Engine DECALS in accordance with ORIGINAL. CUSTOM BUILDS based on aircooled 6 cylinders passion. |
Bringing up an old one. I have a new horn button that has two contact pins. Supplier says to use either or. Did that on either. Then or. No workie. When I touch the wire to the steering wheel horn works fine. Stumped on how to make the new horn work. Even tried connecting both to the single wire. Nothing. My button is just like the button on page 1 but with two, not one point on back.
84 911 03 996tt 09 GT500- for sale! 06 325xi 11 FX4 |
Hmm
When the wire is connected to the tab, is the tab connected to anything in the button that when you press down on it, would seem to press a metal piece into the sides of the wheel?
I don't have my button in front of me, but I want to say that tab linked up to a wire that ran around the edges of the button. when you tap the button the wire connected to the tab hits the edges of the wheel and then it completes the circuit. Hopefully this isn't an obvious answer you already tried.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Figured it out. Very interesting and no instruction on this at all. My button looks like the last pic in post #3 above but has two contacts. Tried every which way to wire. Then, decided to pull on that metal piece on the side that contacts the side of the steering wheel. Well, fully extended it touches the momo hub and not just the steering wheel. Works like a charm on one of the contacts. Horn stays on constant if wired to other contact.
It wouldn't work touching the steering wheel only but did when hitting the hub.
The MOMO Steering Wheel Hub Adapter description says that it may lose cruise control. I do not think this is an issue in G-series cars where the cruise control stalk is below. Can someone comment?
Thanks! |
Wer bremst verliert
Thanks again for posting this, helped expedite an install for me tonight!
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Hello... I am trying to get my horn button working. PO cut the wire and removed the horn ring, so I had to buy a new one. I now have the horn ring, but I noticed in these pics there is a wire coming out of the small hole/notch in the upper left of the MOMO hub. What is this wire? I do not have it. I only have the wire that is attached on the horn ring that I then plug in on the MOMO horn button. ALSO... can someone post a pic of what they did to replace the OEM wire with the MOMO supplied wire (as the connector is larger than the Porsche part)????? Thank you so much!!!
1987 Porsche 911 Carrera Coupe |
Porsche 4 life!
Ok so this is where I lose my intelligence. Please help!! Am I correct that in my ‘86 Carrera I remove the oem wire from the back of the oem wheel and before screwing it into the hub I need to remove the oem connector and somehow attach the larger head the came with the momo hub? Is there no other way to get the horn to work? i.e. use the oem wire and then some how use the momo hub wire as a ground...but I’ve not seen any obvious location to screw the wire that came with the hub any where....any guidance is appreciated...this is the only part of the install that has me confused. Tyvm!!
In my case (same '86) I did not cut any wire/connector. Simply got a spade lug adapter to connect both wires and used electrical insulating tape (or heat-shrink I forgot) around the connection.
I also mounted a spacer (available from Pelican) at the bottom of the new hub, as otherwise the steering wheel rim is very close to the top of the dash.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl Last edited by adias; 07-25-2019 at 05:08 PM.. |
Has anyone used an eccentric adaptorwith the protipo 350mm to improve gauge view.?
FWIW, that's a vintage flat (non-dished) Prototipo. Difficult to source. Nice find.
Sherwood |
Porsche 4 life!
I do not recall. You have to measure both spade lugs and perhaps fashion a flat connector pad made of copper. Use a caliper and go to a parts store, get something and adapt it. Get some shrink-wrap too.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl |
Porsche 4 life!
Great write up ty! I’m curious the change of the spade, is the new spade obtained by cutting off the larger spade size from the wire that came with the MOMO Hub?
Porsche 4 life!
Thx for this thread! The install went great, cut the oem wire and slapped on the momo wire, the grounding plate between the wheel and the hub, the tab faces away from the driver but is then the tab is bent towards the horn button so it will make contact when you engage the new horn button. Beyond that easy to do!!
I need to order the hub adapter and not sure which one to order (long or short). Thanks
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
I use the eccentric adaptor with regular adaptor and it not only improves viability for the 350mm protipo but it adds a wee bit of extension as well...great combination effect
