Rolling an engineless/trannyless 911 - okay to do?
Reluctant to ask this because it seems a dumb question. Did a search, but no juice.
The scenario is your engine and transmission are out of the car and the CV/axles are unattached at that point. Can the car be rolled (pushed) to another location (50 ft. or so) to get it out of the way without any problems? Any precautions need to be taken? |
you got to string up the driveshafts or they will bind up and you could damage them. anything will do to hold them up.
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Okay, then. Unless someone else adds any additional precautions, I will proceed to simply support the drive shafts and roll her away. Thanks.
Just did the same last night, except that my axles were completely removed from the car.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
GAFB
It just takes another couple minutes to yank the axles as yelcab mentions (unless the hardwares is frozen, BTDT). Otherwise, just string up some coat hangers to support them. Unless they are already dirty, it is also helpful to ziptie a plastic grocery bag over the axle ends. Keeps dust and dirt from contaminating the grease in your CV joints.
Several BMWs |
Senior Member
The stub axle must be not be loose in the rear bearings when you roll the car or you will destroy the bearings. Only roll the car with the stub axles in place and at least some decent torque holding that bearing together.
A diagram for reference (Item 5):
From the picture 2a or 2b should be on there
Non Compos Mentis
Wire coat hangers around the upper shock mounts.
Make sure you are able to stop it once it starts moving.
-W
"88 Commemorative Edition Carrera - RIP replacement - "90 Carrera 4 |
John is correct.
DO NOT move it or roll it if the stub axle (#5 in the diagram) is out/loose. You will destroy the bearing. Tinker |
Irrationally exuberant
For moving a car around with the axles. I make a "tube" by wrapping cardboard around the axles and then support the tube. One tube holds up both axles. Damon (Series900) told me about this trick.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Just popped in to say thanks for the tips, guys.
Now glad I asked the initial "dumb" question
I use plastic trash bags,My car is like that most of the time
My projects never end Last edited by dc96819; 12-16-2003 at 03:13 AM.. |
and secure a rag around the CV joints to make sure the balls stay in their races. Not good to mix the balls.
Done it plenty of times. Your brakes should work fine. Make sure someone's sitting in the driver's seat to steer and brake.
2026 BMW X1 2023 BMW S1000R 2022 BMW 530i |
