universeman's Avatar
Should I be worried? Melted/deformed fuel pump relay
Guys,
I pulled out my fuel pump relay while testing CIS pressure and this is what I found - should I be worried? Looks as though the relay is getting extra-hot.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 09-02-2015, 04:36 PM
pors1968's Avatar
Probably not the pin would change color .
Old 09-02-2015, 04:52 PM
What do the fuse contacts look like? #6 fuse.
206 637 4071
Old 09-02-2015, 05:23 PM
sugarwood's Avatar
What exactly is wrong in the picture?
1986 Bosch Icon Wipers coupe.
Old 09-02-2015, 05:27 PM
FP relay manufacturer.......
Could you post picture of the top of the relay? First come to mind is 'Made in China'. If that's the case, look for a better quality FP relay for replacement.
Tony
Old 09-02-2015, 05:50 PM
Picture of fuse #6 and relay (Made in China):
Fuse contacts look good John. Warping from relay appears to be heat-related.
https://www.icloud.com/sharedalbum/#A25yeZFhvcMhV;FEF99ED1-6D8D-41EC-B63E-F715D630C9D2
Jason - Austin, TX
92 968 coupe
Old 09-03-2015, 09:30 AM
Jason - Austin, TX
92 968 coupe
Old 09-03-2015, 09:31 AM
T77911S's Avatar
clean the fuse and fuse contacts. remove the wires and clean the ends of the wires along with the screw that contacts the wire.
drive the car and cehck fuse and relay for temp.
you could even remove the fuse and connect an amp meter in its place. should be around 7 amps.
get a bosch relay
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-03-2015, 10:25 AM
I wouldn't run any Chinese electrical components in my car, or my house.
The plastic fuse body will soften before the metal prongs will discolor. If you have a high resistence, eventually that circuit will fail. You may even have to replace the fuseholder.
I don't like this fuse, at all:
You have a fuse that doesn't look like it is seated well, the wire end is frayed, the wire insulation is discolored from heat...
Make sure you use good fuses. Some of them are crap. You have several different types in there.
JR
Old 09-03-2015, 11:29 AM
JR
The appearance of the circled fuse is very common. It's a 25 or 30amp A/C fuse and provides 12v for both the evaporator fan AND the front condenser fan. Too much current for that single circuit. A lot of folks have split the load to two fuses to prevent what you see in the pic! Plus a third inline fuse to the front condenser fan to prevent a known FIRE hazard!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-03-2015, 12:07 PM
