beamonk's Avatar
Send a message via AIM to beamonk
pulse generator wire
I just received my "green wire" from PP. the one I received is about 3" long and does not look like it will work with my 83 Euro SC motor. Is there a longer one available? I don't think mine has a connector in the line except for the one that plugs in the distributor. I need to look closely at things tonight. any insight anyone?
John Brasfield
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 02-26-2004, 10:49 AM
Early_S_Man's Avatar
Porsche Crest
John,
There has been plenty of discussion about the green coax ...
http://forums.pelicanparts.com/search.php?action=showresults&searchid=598110&sortby=lastpost&sortorder=descending
I believe the replacement cable for your application is around $200.
As I see it, there are two solutions to your current situation without spending an additional $200 ...
1. Cut your existing green coax back, assuming that there is 'good' non-cracked insulation in the vicinity where the 3" pigtail would need to connect to the 2-pin Bosch connector. Acquire mating Bosch [it is a generic VW, Mercedes, et al part] connector housing, and the 0.110" Faston connectors ... cut, strip, and crimp & solder the Faston connector pins to existing green coax, then press into mating plastic connector that will connect to 3" pigtail.
2. Build a new cable using RG-180 or RG-188 Teflon-insulated coax, rated for -70°C to +200°C service ... 100 feet (minimum purchase) is around $20 ... put two 0.250" Faston connectors for CDI end and two 0.110" Fastons to connect to distributor.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-02-2004, 03:19 PM
David's Avatar
I don't know about the 83, but I just put one on a 78. It took about 15 minutes to pull the distributor, replace the wire, and reininstall the distributer. The wire I got from PP was $31 and about 4-5 inches long. Can the connector it plugs into be pulled closer to the distributer?
Old 03-02-2004, 04:01 PM
