Does anyone know what needs to be changed or modified to install the early 80's clover leaf wheel on a early car 70-73??
04 996 TT 71 911E 73 911S Targa 61 356 Coupe 69 XKE OTS 68 XKE Coupe 65 Healey BH8 |
You need absolutly nothing except a clover leaf type steering wheel and a socket with an extension to remove and align and replace the old steering wheel with the new one. (I guess that is two things that you will need.)
It won't go in far enough to even start the nut and I don't see how it will cancel either.
Post some pics, and the folks on this board will figure it out.
My thinking is you are wanting to use a wheel that has the "crash cushion extension" in it onto a stem that was never designed for one. Good luck, David Duffield |
