Question Should/Can I drive my car like this?
My car is an 86 Carrera.
I replaced the alternator with a rebuilt one... however when the lights are on and the car revs over 1500 RPM, the Alternator Light starts to glow. It glows very dimly and gets progressively brighter as the RPMs increase.
Today, I replaced the battery with a brand new one from Auto Zone, however the problem still remains: Alt Light Goes on at Revs when lights are on.
This is my daily driver vehicle.... and I am scheduled to drive 100+ miles on Tuesday and 250+ miles on Wednesday.
I will not be able to get a replacement alternator until the end of the week.
Is there any potential to damage my car, or have the car die when it is in this condition? Id hate to be stranded again....
Thanks...
Old 01-24-2005, 02:45 PM
Crusty Conservative
silverc4s's Avatar
I would be concerned about damaging your DME if you have a faulty regulator / alternator.
Is that the same symptoms as before the replaced alt??
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 01-24-2005, 02:48 PM
SC-targa's Avatar
I wouldn't drive it until I figured out what was going on. Have you checked it with a voltmeter or and ammeter?
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 01-24-2005, 02:50 PM
Yes... voltage appears to be within tolerance and spec, though a bit on the low side.
I dont remember the exact numbers but it was close to the range specified in Bentley Manual, when not started, at idle and also when over 2000 RPM
Old 01-24-2005, 02:58 PM
disband
juanbenae's Avatar
could you have reattched something out of place? wires swapped?
Old 01-24-2005, 03:09 PM
Not likely, there are three wires (actually 4 but 2 are grounds) and I hooked them up exactly as was before to the proper terminals...
I may just pull it out and check it again tonight. The belt is totally tight. Guess Id better get to work on it...
Old 01-24-2005, 03:12 PM
Air Medal or two
afterburn 549's Avatar
Diod out in alt.??
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 01-24-2005, 03:34 PM
