ausgezeichnet's Avatar
Use of a 944 DME in 84 3.2L Carrera
I've read that DME's from a 85.5 and later 944 have been used in Carreras. Can the DME be use as is (other than the chip replacement) or do other mods need to be made to it? Also, does the 944 DME take a 24 pin or 28 pin chip? Thanks.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 02-11-2005, 05:48 PM
Irrationally exuberant
ChrisBennet's Avatar
From memory, the 944 DME hack involves changing a precision resistor in the injector driver circuit and changing it from 24 pin to 28 pin EPROM.
Not that you asked, but you'd be better off fixing your own DME if it's broken.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-11-2005, 06:35 PM
Thanks. I was just looking for a spare DME for testing to make sure my original is indeed bad. All the cyclinders on the right bank stopped firing which leads me to believe the signal from the DME for the fuel injectors for that side may be bad. Amazing how it runs on only 3 cylinders.
Mike
'83 911 SC Coupe
Old 02-11-2005, 06:44 PM
Lorenfb's Avatar
"All the cyclinders on the right bank stopped firing which leads me to believe the signal from the DME for the fuel injectors for that side may be bad. Amazing how it runs on only 3 cylinders."
Not true! The 3.2 DME has ALL injectors connected to a common point in the
DME.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 02-11-2005, 07:41 PM
Loren,
Do you know why there are 2 separate pin assignments for the left and right bank in the ECM that control the injection time signal. According to the DME fuel injection diagram in my Bentley manual (page 240-38) they never come to common point. Am I missing something? Thanks for your help.
Mike
'83 911 SC Coupe
Old 02-12-2005, 07:04 AM
Lorenfb's Avatar
That design (2 separate wires) reduces the current requirement of each wire
and thus reduces the wire size, i.e. voltage drops when pulsing the injectors.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 02-12-2005, 07:55 AM
Loren,
Ok. That makes sense. So could a bad output from either terminal 14 or 15 in the DME in this design cause one bank of cylinders not to fire? Thanks.
-Mike
Mike
'83 911 SC Coupe
Old 02-12-2005, 08:30 AM
Lorenfb's Avatar
Yes, but only if the circuit board in burned near pins 14 & 15, rarely happens.
Most likely the injectors don't have +12 volts on the "dead" side,
or the common return line to 14/15 is broken.
1. Remove one injector on the dead side and check for +12 volts
using a test light.
2. Check continuity of the injector wiires.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 02-12-2005, 09:18 AM
