Alusil or Nikasil on 83SC ROW
I have done a search on Alusil and Nikasil and found heaps of info. But it appears that you have to have the engine apart to tell if you have Alusil or Nikasil cylinders.
My mechanic told me that since I have a 83SC ROW with a 9.8:1 CR the cylinders are Nikasil. Is this correct??? I am looking at a top end rebuild soon and would like to know.
Damo 83SC 'Guards Red' - Sold 1994 993 C4 |
Go Speedracer, go!
I have heard the same about the later RoW cars, but never a definitive answer. I would like to hear what the experts say. Too bad there isn't a way to tell without looking inside the cylinders.
1981 SC ROW Coupe |
Somatic Negative Optimist
It's a crap-shoot. You don't know until you open the engine. Only a few people have re-ringed Alusil P/C. Consider going to 98mm P/C along with 964 cams, if you find Alusil P/C in your engine.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Spec book says all 930/10 motors (late RoW SC) had Nikasil/Mahles. That's what mine has.
I had an late 83 with the 3.2 case sans oil sump plate, K&S alusil setup.
diy83SC
Dumb question. How do you know if you have a 3.2 case? Tom If thats correct that would correspond to the 81 - 83 models with 9.8:1 CR. I maybe lucky.
Go Speedracer, go!
1981 SC ROW Coupe |
Sorry to go off into a tangent, but could one of you experts tell me if 3.2 ROWs are nikasil or alusil? Mine is 1985.
Thank you in advance. |
The case *may* have been a 930/16; the car is gone now so I don't know for sure.
How you can tell it's a 3.2 case is that it does not have a sump plate, just a drain plug...
It seems all ROW 3.2's ( those w/o cats) ...are Nickasil
Look at your cylinder fins....is one with 10 fins and no vertical reinforcing bar....and the other 11 fins with vertical reinforcing bar. Not definite...but 11 is usu Nikasil..... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wil:
I was lucky to find Mahle Nikasil P/C on my 3.0 liter; but, they did not have the verical bar. I still think that it is 50/50 for what you have in any SC or Carrera.
Gunther...true enough...for cars meant for the states...
I'm quite certain ( 3.2's at least) that non cat Euro (ROW) cars were all Nikasil. Yes, there were cat Euro cars built to take advantage of a special tax break. But you might be right for VERY late production 3.2's...if Alusils were around, they probably used them up. Wil
niks have 11 fins, alusils have 10. niks have a dull, glass beaded look on the outside, alusils are shinier, even a bluish cast to the aluminum.
Thank you. That's what I was afraid of. I heard enough horror storries from BMW community with Nikasil.
Go Speedracer, go!
1981 SC ROW Coupe |
drag racing the short bus
The Terror of Tiny Town |
Let me clarify about BMW story. Sorry, it's kinda long.
A long time ago a Galaxy far far away........it involves 5-series BMW V8 such as 530i and 540i that was produced early 1990's. I guess back in 1980's BMW used Nikasil in their motor cycles. BMW car division heard of this application in motorcycle and decided to use it on the next version of their V8. The engine went thru the usual testing phase at Munich. They found the Nikasil to be quite beneficial to the new engine. So, they went ahead with North American launch in 1990. What they didn't count on was that unlike Euro gas, the sulfur content on US gas is much higher. The amount of sulfur is depend on brand of gas and geographical region. Apparently, sulfur from gas react with Nickel in Nikasil in these engines and eat away the cylinder wall. This caused the premature wears on the engine. When BMW NA finally realized the problem, they tried a quick and dirty solution by reprogramming the ECU to increase the heat on the engine. Their rational was that increased heat will delay the reaction between Nikasil and sulfur. But, this did not work at the end. BMW finally decided to bite the bullet and recall the engines. They ended up replacing Nikasil engines with Alusil engines and never looked back. (Luckly, Alusil was available on their 7-series at the time.) The recall was issued to the customers who complained so, there are still a lot of Nikasil engines out there. That is the reason these early 5-series with V8 has lower resell value that 6 cylinder models. I heard a similar situation with Jaguars, but I think, I bored you enough already. The ironic thing is, the new US gas regulation reduces sulfur content in gas, so Nikasil is no longer an issue in the near future. |
Go Speedracer, go!
Yes, i have read about the Nikasil problems in BMW engines here a few times. It seems though that it is isolated to BMW, and Porsche engines don't suffer from the same problems. I'm not sure why though. From everything I have read here, Nikasil is the one to have in a Porsche engine, but again, I'm not sure why.
1981 SC ROW Coupe |
Maybe porsche doesn't get affected because of cylinder wall lining. BMW didn't have them if I recall.
