Kind of Blue
MrBonus's Avatar
Originally Posted by MyFlat6 View Post
Lot’s of little things that added up to weight savings. Focused more on lightening the rear of the car. I tracked everything in a spreadsheet, but some examples are aluminum decklid, license panel and bumpers in rear. Stripped interior with minimal lightweight sound deadening. Lots of other small things - I have a build thread on Rennlist if interested in more detail. It is a modest, sleeper hotrod. Fun as hell!
Gorgeous hot rod and in many ways, similar to my own! I have rear seats deleted, RS door pulls, no AC, no stereo. You're really making me want to put it on a set of scales and see what mine weighs.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 06-04-2021, 10:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1461 (permalink)
Thanks! Just removing those items will make the largest impact. Also, I focused more of my effort towards the rear of the car. While I didn't go nuts lightening my car (it is a sleeper hotrod), here are some examples of things I did to lighten the car:
1) Going from stock cast iron cylinders to Nickies - saved 30lbs (and off the rear!)
2) Stripping the interior (lighter steering wheel, door handles/pockets, radio, speakers, antennae, ashtray, seat, parcel shelf, sides, sound deadening, lightweight carpet, lighter seats, etc) - saved 85lbs
3) Removing A/C - saved 60lbs
4) Aluminum decklid, license panel and bumpers - saved 17lbs
5) Hi-torque starter - saved 7.5lbs
6) Fiberglass engine tin, removed snorkel and air flap, ST cover - saved 7lbs
7) Alloy brake calipers - saved 5lbs
I also have a lighter spare tire, no tool kit, no jack, single battery, no frunk carpet, no water bottle/window sprayer system, SSI's and sport muffler. I stuck with 6" Fuchs all around. Also, I have the early Mag 915 gearbox and stuck with the early Mag case for my motor build, plus a lightweight clutch pressure plate. Also a non-sunroof car. The MFI pump is heavy but I wanted to stick with MFI
I added weight to the car with larger torsion bars, front and rear sways (T's didn't come with them) and a front oil cooler setup. Could have been even lighter - but I think I need these upgrades!
After these things, it gets more difficult and expensive to lose weight.
Old 06-04-2021, 02:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1462 (permalink)
Doug&Julie's Avatar
I love that this thread is still going strong after 16 years!
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 06-04-2021, 02:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1463 (permalink)
Kind of Blue
MrBonus's Avatar
I also have a lighter spare tire, no tool kit, no jack, single battery, no frunk carpet, no water bottle/window sprayer system, SSI's and sport muffler. I stuck with 6" Fuchs all around. Also, I have the early Mag 915 gearbox and stuck with the early Mag case for my motor build, plus a lightweight clutch pressure plate. The MFI pump is heavy but I wanted to stick with MFI
Very nice! That's quite an undertaking. Any idea what kind of power your motor makes?
Mine is a 911 transmission, I believe original to the car, and a '77 case (mag?) that was rebuilt in the mid-90s with a pair of triple throat Webers, long prior to me taking possession. I am running 15x7s all around which were rubbing due to the 65 height tire the car came with which I replaced with 205/55s all around.
It had an old OEM muffler that I swapped for a dual in/single out M&K exhaust. I too don't have a carpet in the frunk (threw it out - smelled bad; didn't feel a need to replace).
I plan to order the lightweight battery mount kit from Patrick Motorsports as this car has an oversized, poorly mounted Optima dropped where the charcoal canister mounts.
The two prior owners did most of the "heavy lifting" on the build. I've just been slowly refreshing/fixing things.
Old 06-05-2021, 06:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1464 (permalink)
^ sounds like you have some good plans for the car and have made some nice changes already.
My motor is estimated around 200hp.
Old 06-05-2021, 01:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1465 (permalink)
Coming ..... sneak peak
ETA August
Screen Shot 2021-06-03 at 6.14.15 PM by Steve Heck, on Flickr
Old 06-06-2021, 04:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1466 (permalink)
1971 Hot Rod
Here is my '71T running a '76S motor with ground cam to allow for the period correct
Webers. Seats, modern seat belts, and radio removal are next on the list.
Old 06-09-2021, 10:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1467 (permalink)
cycling has-been
bkreigsr's Avatar
ETA August
Flickr
hmmmm
doesn't not look like the rest of the NARROW BODY hot rods in the thread ????
Old 06-09-2021, 11:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1468 (permalink)
BEAUTIFUL car, PCarb. Nice first post too.
Old 06-09-2021, 11:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1469 (permalink)
It took only 49 years!
mclmk8d's Avatar
New photos, taken at the 1st annual Ruchlos Rallye to Snowshow Resort this past weekend and at the Philadelphia Navy Yard:
Serge: In the heart of Philly!
Daisy - 1972 911T 2.7L Light Yellow
Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD
Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
Old 06-09-2021, 12:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1470 (permalink)
Ayo Irpin, Ukraine!
70SATMan's Avatar
ETA August
When do the training wheels come off? Albert Blue?
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 06-09-2021, 04:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1471 (permalink)
Thanks for the kind words. I've been a reader for a very long time ( The information available on these forms is amazing), and a member for just about a year, but I figured I would jump in on the posting today.
Old 06-09-2021, 06:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1472 (permalink)
Sheck44's ride is not Albert, but coincidentally, mine is.
Maybe it is Oslo Blue? Regardless, it's coming along nicely.
Old 06-09-2021, 06:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1473 (permalink)
Kind of Blue
MrBonus's Avatar
Love it!
Old 06-09-2021, 06:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1474 (permalink)
Wow, drops mic. The chrome trim really sets it off and shows the timeless lines. Great detail there. What size campos are you running?
Old 06-09-2021, 07:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1475 (permalink)
Originally Posted by bkreigsr View Post
hmmmm
Yup ... my bad !!
Training wheels ...LOL, you guys kill me
Old 06-10-2021, 04:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1476 (permalink)
Ayo Irpin, Ukraine!
70SATMan's Avatar
Yup ... my bad !!
What's the color Steve? Gorgeous!
Old 06-10-2021, 07:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1477 (permalink)
1972 E
2,400 Lbs
2.7 RS Engine
Upgraded brakes
Recaro SRD seats
Plenty performance, lots of grins.
Old 06-10-2021, 11:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1478 (permalink)
Thanks Mike, much appreciated !
Ok so the colour is 'Montana' Blue ... its a colour 'borrowed' from a high end builder
Cheers
Old 06-10-2021, 01:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1479 (permalink)
Thanks, Salazar. The wheels are 7x16 all around.
Old 06-10-2021, 02:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1480 (permalink)
