-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Newbie Question: Regarding Exhaust Heat (http://forums.pelicanparts.com/showthread.php?t=225616)
Johnathan 06-09-2005 02:23 PM
I recently purchased my first Porsche. It's an '83 911SC Coupe. Absolutly love the car. But, I'm still trying to figure out what is normal and what is not.
After driving it for a while and getting the temps up to normal operation. When I park the car, the top(and I presume bottom) of the rear bumper are hot (very hot) to the touch, as is the bottom of the hood, and the place where the info stickers are. I realize that the mufler is directly behind this but is this normal?
Thanks.
Bill Verburg 06-09-2005 02:33 PM
is this normal?
Yes, somtimes people vent and or insulate the area around the muffler
http://forums.pelicanparts.com/uploa...1109007518.jpg
Jack Olsen 06-09-2005 04:57 PM
Does it have a stock muffler?
Johnathan 06-09-2005 05:01 PM
Yup, stock muffler, exchangers, etc.
kqw 06-09-2005 06:17 PM
It's normal..However, if it's EXTREMELY hot to the touch, check to make sure all your shields (muffler and cat) are in place.
Sumotang 06-09-2005 07:06 PM
The '83SC is a great car :D :D :D :D
Got any pics?
Johnathan 06-09-2005 07:09 PM
Yup, Here's my baby..
http://forums.pelicanparts.com/uploa...1118372896.jpg
Sumotang 06-09-2005 07:28 PM
Very nice. Love the Turbo Tail.
mmastro 06-10-2005 06:28 AM
If you don't have the stock sheet metal heat shield, you could install one and it'll bring the temp down. You could also line the inside of the rear bumper with ThermoTech. It's basically a silica fiber (fiberglass) sheet with a really durable adhesive for applying it to the inside of your bumper (clean it really well first).
I have a 77 930 w/ stainless exhaust/muffler and a red-hot turbo (most of the time :) ) and the ThermoTech along with the stock Carrera heat shield did the trick. I have a fiberglass RSR rear bumper on it now... I melted one bumperette and bubbled/burned the paint on my stock set-up prior to the heat management mods.
Cheers
EDIT: forgot to mention...NICE CAR!! ;)
trak ratt 06-10-2005 05:15 PM
You could also check the timing and fuel mixture. Retarded timing and lean can cause very hot exhaust. I once had a Harley and forgot to advance the distributer after start up. Riding easy down the Parkway after dark didn't notice. After a few minutes looked down and the header pipes were bright red for about 8 inches below the heads :rolleyes:
vash 06-10-2005 05:17 PM
damn, nice. very nice!
Emission 06-10-2005 08:05 PM
Mine gets really hot too (and I have the heat shield and ThermoTech!). I always open the decklid when parked at home to let the heat out, and more recently run a fan to blow cool air on it too. I figure the heat is doing terrible things to the hoses I spend 2 years replacing, so the less heat the better.
Johnathan 06-10-2005 08:35 PM
Thanks for all the replys and the comments on my new (first) baby (I've been wanting one since I saw a friend of my dad's doing some pca club racing back when I was 7 yrs old)
I'm not sure if I have any kind of heat barrier around the muffler but I will definatly look into that this weekend. I like the suggestions of insulating the area around the mufler.
In looking through the bently service manual I notice there is supposed to be a shield around the bottom of the cat. but I don't have one on my car. Any big issues here?
kqw 06-10-2005 08:39 PM
Just looking at the picture: Am I correct in not seeing a rear valence????
Johnathan 06-10-2005 08:39 PM
I too have opened the decklid and turned a fan on it... even though my neighbor thinks I'm being obsessive.
Johnathan 06-10-2005 08:41 PM
If the rear valence is tha part that is cut out where the exhaust tips exits the, yes this has one. However, the right side was cut open for a dual out muffler..... that was removed sometime before I bought the car.
kqw 06-10-2005 08:44 PM
Look to see if the shield that mates to the valence is still there. The heat shield hugs very close to the valence....
Johnathan 06-11-2005 03:19 PM
Alright, I've taken a look and didn't find any shield. Any ideas on where I might find one and/or some of the ThermoTech.
Emission 06-11-2005 06:49 PM
Johnathan,
Can you take a pic of what it looks like under there? We can identify what is missing...
Johnathan 06-12-2005 03:20 PM
http://forums.pelicanparts.com/uploa...1118618292.jpg
Here's a picture of the bumper/muffler area. Is there a heat shield missing here?
