-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   DIY 134 conversion in SC complete! (http://forums.pelicanparts.com/showthread.php?t=226027)
Tim Hancock 06-12-2005 12:44 PM
I have seen some other recent posts on AC systems, so I thought I would post my some of what I did last week.
My '79 SC with stock York compressor did not work and the PO claimed that he thought it worked about 5 yrs ago (whatever!).
My clutch worked but there was absolutely no pressure in the system. After reading many posts and talking to friends with AC knowledge, I decided to attempt a 134 conversion.
First I ordered a new drier from a local Advance Auto Parts for $18.83 (it ended up having the proper male 45 deg 3/8 flare fittings but they were oriented wrong so I purchased a couple fittings and fashioned an alum 180 deg aluminum tube to allow it to work).
Next I rigged up my homemade CIS tester to attached to the male
flared fittings on the service valves and pressure tested the system. I found a gross leak on the low pressure hose near the jack point (the bad spot matched my partially smashed oil lines, imagine that!). I made a splice with 1/2 brass hose barbs and wide hose clamps. Next I sprayed all fittings with soapy water to look for additional leaks and found none.
I happened to notice that the port on the York (top) that was marked discharge had the low pressure (big) line attached. Obviously the PO's hack mechanic had disconnected the lines at a previous engine drop and reattached wrong. I reattached correctly. Only the low adapter that came with the kit fit my blow port. Note there are no shrader valves on a '79 SC. You have to crack open the service valve to check pressure or add freon. Turn clockwise a couple turns to charge, then CCW to shut off service port to change 134 cans then repeat.
Next I borrowed a vacuum pump and evacuated the sytem for several hours. Next I added the three cans of 134 and 1 can of 134/oil mix following the directions that came w/ the kit. (these kits are sold at all chain auto places for 30-45 bucks)
On a 88 degree day I am getting 45 degrees at my air vent.
I live in Ohio and the summer temps rarely top 85-90 so I am very happy thus far. Hopefully th system stays charged, if not I will inject dye and fix any additional leaks.
I got the "extra" 134 coversion kit from a friend so about $25 for a drier and fittings and a couple evenings of troubleshooting and I have IMO, great AC. I couldnt be happier! (or cooler)
Early_S_Man 06-12-2005 02:10 PM
Tim,
How did you rinse/flush the system?
Did you drain the old oil from the York compressor???
IIRC, the York needs new ester oil in the sump ... not just circulating about like the swash-plate compressor systems in most cars these days, i.e., Sanden/Seiko type compressor.
Paulporsche 06-12-2005 02:38 PM
Do you have barrier hoses?
Tim Hancock 06-12-2005 03:51 PM
I do not know what style of hoses came stock on the 79 SC, but the one I cut and spliced had about a 3/16 wall black rubber tube surrounded by a ss braid surrounded by a cloth type cover. I had to use a die grinder/thin disk to cut the bad section out. If I have to add a 1-2 cans of 134 a year I do not mind.
I have a friend who has done this same procedure on other 911's and has not noted any problems. I considered draining the pump, but in the end I decided against it. Warren, what is your basis for saying that I have to change the oil in a "York" type compressor? Does the oil not travel thru the system the same way as other compressors?
I have heard a lot of myths concerning AC and in the past I have always taken my cars in for AC service. My last car that needed work, 1992 BMW 325i got recharged with 134 (was r12) and has been blowing cold for 3 yrs and has all original hoses, pump etc. and 245,000 miles on it. I was worried about doing this as I had read all kinds of stuff about how I needed to flush and replace hoses, o-rings etc. The place I took it to just changed the fittings and I supplied them with a new drier and that was it.
Oh well, time will tell I guess. Worst case, I will have to buy a different pump and fab up a mount bracket and come up with some fittings. Not a big deal I guess. But man is it nice now!
cmonref 06-13-2005 03:35 AM
Regarding Warren's question about your oil:
If your system was charged with the original R-12, it used mineral oil in the A/C system. You are right -- the oil mixes with the R-12 and is carried around the system, lubricating the compressor in the process.
But 134a and mineral oil are not compatable, and the 134 will not carry the mineral oil around. The compressor will not receive regular lubrication, with predictable results.
Conversion from R-12 to R-134 requires changing the drier, flushing the system to remove the mineral oil, and using ester oil.
Tim Hancock 06-13-2005 05:55 AM
The kit retro kit I used, had (1) can of ester oil (I think it was 8 oz) included which I added.
The kit claimed the ester oil would travel thru the system satisfactorily, while any remaining R12 oil would not cause any thing detrimental to happen.
Time will tell (it has worked fine in my Bimmer thus far after 3 yrs).
I have read in the past that hoses made for R12 should not work for 134,
but since then I have read that the oil in the original R12 system over the years, impregnates the rubber hoses and when converting to 134, the hoses that when new would not work for 134, actually work now.
In theory, I do not disagree with you guys that are advising to flush, change hoses and change compressor styles. I have spent about 7k on this car since I bought it and it is getting close to being sorted out now.
No way am I going to blow 2K on all new hoses, compressor etc etc just to have air that is a few degrees colder. If I have a leak, I will find it and fix it. If my 26 yr old York gives up the ghost, I will replace it w/ a modern rotary compressor. If I find that my hoses leak more than I can
live with, I will purchase bulk AC hose and replumb the whole system.
If my $25.00 "fix and retro" that I just did, continues to work, I will have a big smile on my face.
cmonref 06-13-2005 06:07 AM
Hard to argue with your approach!! Good luck!
herman maire 06-13-2005 07:02 AM
Im about to convert over to the r134 gas on my 5 series.
a few questions
Did you have the system flushed and did you change the oil in the compressor.
Do you think it would be okay if I just flushed the system and put in a new drier, and left the compressor oil alone.
Does this make any sense or does the r134 oil/gas lube the compressor and there is'nt even oil in the compressor.
let me know
thanks
Tim Hancock 06-13-2005 07:30 AM
herman,
DISCLAIMER:
What I did is regarded by some as the wrong way, but my 3 series BMW was just evacuated, new drier, then recharged w/ 134 along with a shot of ester oil. This was done by a local auto shop and they did not mechanically drain anything (only evacuated refrigerant from system w/ vacuum).
I can't tell you what is best, but I did not drain my mineral oil in my 911 but some of it had gone bye bye thru my gross low pressure hose leak and whatever was still in my old drier. After repairing my hose and replacing my drier, I pulled a vacuum with a vacuum pump for several hours then installed the 134 and ester oil that came with my 134 conversion kit. So far so good.
mtelliott 06-13-2005 09:34 AM
Thanks for the write-up. Now we just need the long term test to occur.
Anyone know how much it would cost just to replace all hoses? My AC has been dis-installed for over 5 years and the hoses running underneath look rotted and cracked. For me, I think it would make sense to replace the hoses and then follow Tim's advice and put in a new dryer and see what happens.
Michael
greglepore 06-13-2005 10:06 AM
I agree w/ Tim that older non-barrier hoses do in fact work-my Carrera was converted to 134 a couple years back by a shop on the the cheap (added a procooler as well) and it works fine-I add maybe a half can or so of 134 at the start of each season, no biggie.
Tim Hancock 06-13-2005 10:07 AM
The low pressure hose running on the right side was super tough and unless you snagged it or smashed it w/ the edges of a floor jack cup (like I found mine) I would find it hard to believe that that hose would go bad (it had about 3/16" wall thickness surrounded by a ss braid surrounded by a cloth braid).
yasir 06-13-2005 11:07 AM
I was told even 134 would be obsolete in 1-3 years,so what's next ? It seems like i might have to make the switch in my C2 Turbo as well but i need to know what to switch to ?
Tim Hancock 06-13-2005 11:40 AM
I heard freeze 12 or something like that works good also, but a 134 fill-up from empty (3-4) cans at $10.00 a can at the present time is a simple choice (hell, I got mine free, even easier choice!). If it goes obsolete in a few years, I'll buy a new $20.00 drier, evacuate and put something else in it.
Tim Hancock 06-29-2005 11:37 AM
Update on above described DIY 134 conversion/repair with 26 yr old stock York compressor:
It has been 4 wks since I did this and all is well (no black death or whatever it is called). My vent temps while moving down the road on 95 degree days is holding at 45 degrees. I have driven 80 miles round trip nearly every day with 85-95 degree temps (why is it so f'ing hot in Ohio in June?!?) The first few miles on the way home are stop and go and it IS warm in the car until I get to the highway at which point the car cools down quickly and after about ten miles, I have to back down on the AC controls.
Just thought I would give a real world update for anyone else contemplating doing the same.
anthony 06-29-2005 12:15 PM
I'm on the verge of doing my A/C as well. A couple notes:
You can get a Sanden compressor to replace the York for $100-200 on ebay. A York to Sanden bracket goes for $25-40 or you could easily make your own if you are handy with welding.
If you need new lines, one can buy the crimping tool, new barrier hose, and connectors for less than $250.
Tim Hancock 06-30-2005 03:23 AM
Presently, I see no reason to replace the York as I am very happy with how the system works at the moment. If it goes south, like many say it will, I will probably replace w/ something more modern. So far it is the best $25.00 I have spent on the car!
rick-l 07-04-2005 07:35 AM
I am thinking of the conversion to 134.
How do you get the oil out of the system? Can you just dump it out the connections to the compressor? Is the rest of the oil in the drier?
When you say flush it what does that mean? Seems like you would have to remove the expansion valve to run solvent through it.
ruf-porsche 07-04-2005 12:34 PM
I hope you clean out any debris that may have gotten into the hose during the die grinding operations. A/C System don't take kindly to any type of dirt in the system, the orfice of the expansion valve can become clogged and the system won't operate as it was designed to.
I would have use a hydraulic shear or a ratcheting shear from SEARS to cut the line instead of using a die grinder. No debris to get into the hose and worry about clogging the system.
Tim Hancock 07-05-2005 03:39 AM
I did indeed swab the cut hose ends.
Excellant write up Jim.
jimz61 07-05-2005 01:24 PM
Tim,
Did you install an "L" shaped fitting on the low pressure side of the compressor? It seems necessary in order to access the fitting to fill the system. If so, where do I find one?
-Jim
Tim Hancock 07-05-2005 03:24 PM
On my York, the service valves are mounted via swivel type joints to the compressor. I was able to pivot the lower service valve upward enough (rotate it clockwise) to install the low pressure hose from my borrowed AC gages. If you have a York with the service/stem valves, your's should pivot also.
I think it swivels enough to install the low side 134 adapter and charge hose from the cheapo 134 conversion kits, if you do not have gages w/ the sae fittings.
Tim Hancock 04-28-2006 09:28 AM
Having just read a current thread about whether or not to repair AC in these cars, I thought I would post an update on the controversial method I used at the beginning of last summer.
There are a few AC pros on this BB that know their stuff and I agree in theory with most of what they advise when it comes to AC, however I just want to let everyone know that suprisingly, my AC is still working as of last week. I have not put gages on it, but it still blows cold after 1 whole hot humid summer and a long winters nap in storage. I actually figured I would need to add a bit of 134 this spring, but last week I used it on a warm day and it still blows cold!
It still is proving to be the best $25.00 I have spent on this car YMMV!
PS my 260,000 mile, 134 converted BMW AC mentioned earlier is still working good with no recharge in over 3 years. Maybe I should start buying lottery tickets.:D
1982911SCTarga 04-28-2006 09:44 AM
Tim, I'm just beginning to sort my AC and on my York, the suction side has a Schrader valve. The high pressure (discharge) side does not have a Schrader valve. By the way, the system is currently plumbed for for R-12.
I don't quite understand how the system holds pressure on the high side with a plastic cap alone on the test port, or does the backseat valve get screwed in part way or something? If you go all the way in with the backseat valve, aren't you closing off the whole discharge side?
Also, on my York both the discharge and suction valves have 7/8" male fittings.
I've dealt with other AC systems (replaced the evaporator on my wife's Cherokee -- just a simple weekend project). The 911/York system is a little confusing (Schrader/no Schrader, etc.)
Brian
tsuter 04-28-2006 09:55 AM
Of course. The masses of "keyboard" mechanics on this forum over engineer everything.........
Tim Hancock 04-28-2006 10:21 AM
Brian
Brian, I do not have one in front of me right now, but the service valve when the system is in operation mode, isolates the service port (the plastic cap is just to keep dirt out of the service port when not in use). To add refrigerant or monitor pressure with gages, you have to open the service valve so that the now connected service ports are exposed to the system. These service valves typically have a metal protective cap on them that needs to be unscrewed to expose the 1/4" square valve operator stem. I don't remember which way to turn, but I think I detailed the procedure on the first page of this thread.
On the older SC's at least, all the hose connections thru-out the system happen to be 45 deg SAE flare connections (no o-ring connections). Newer cars went to o-rings I think. The ability to go to a local auto parts store for fittings, is what allowed me to easily fab up a tube to allow the generic drier to work out for me.
Porsche_monkey 04-28-2006 10:45 AM
More info here...
http://forums.pelicanparts.com/showthread.php?threadid=165899
Tim Hancock 03-28-2007 03:48 AM
DIY AC update:
After two years of use and after taking the '79 SC out of winter storage and using the AC a couple days ago, it will finally need a top off of 134 as it is blowing cool, but not cold.
Two years before needing a charge on an old York and old lines running 134!
To all the naysayers: :p :D
PS: my BMW I mentioned previously in this post finally required 1/2 a can of 134 at the end of last summer (about four seasons of use before needing recharged)
psychII 05-17-2009 02:54 PM
Thanks for the write-up and update!
I am getting ready to undertake this project on my 928. I would like for this to be a total DIY, but I can't find a place to rent or loan a vacuum pump.
I am planning to dump the oil in the compressor and replace with new, along with new o-rings. With my luck, the system will explode if I don't.
psychII 05-17-2009 02:57 PM
ha
I found this link through another thread and just noticed the date...
hope it has not exploded since 3/07
Tim Hancock 10-03-2009 10:28 AM
Originally Posted by psychII (Post 4668945)
ha
No explosions and it still worked great this summer although I did have to add one can of 134 in June.
G50 10-21-2009 07:00 PM
Tim (or anyone else!),
What exactly does the above mean, how do you do it, specifically?
Thanks!
chamilun 10-21-2009 07:06 PM
you attach a vacuum to they system which 'burns' off any contaminents/moisture in the system. you can rent one from autozone, or buy one for a bit of $$$.
this is needed anytime you open the system
jefferyGT 10-22-2009 03:46 AM
Thank Al Gore for th ehot Ohio weather. And the internet. And thus the Pelican forum.
Tim Hancock 07-14-2010 08:36 AM
Just checking in with my yearly update on my SC's AC condition. Had to put two cans of 134 when it started getting hot this summer and I tried to use the AC.... Not 100% sure, but I believe slightly loose hose clamps on my DIY low pressure hose splice is to blame. Tightened them up and all is well with my old York AC system.
FWIW.... '92 325i BMW that I put 134 in many years ago is still blowing cold at 308,000 miles on the original AC system and hoses.
Willemwild 07-21-2010 10:01 AM
Stupid Question
Sorry, dont want to highjack the thread, but though it may be relevant to the topic and useful to others.
I dont know the history of my recently purchased 911SC (81). Is there any easy way to check if it is still R12 or already converted to 134? :confused:
Tim Hancock 06-24-2024 05:01 AM
After sitting in storage the last 5 years I decided to dig my old '79 911 out of mothballs and get it going again.
On a whim I decided to try to get the AC going again too. (I originally posted this thread 19 years ago. :eek:)
Vacuumed for an hour then recharged with about 3.5 cans of 134 and low and behold it is blowing nice and cold again. :eek: Will have see how it does for the rest of summer. Thought some here might appreciate the LONG term update. :)
http://forums.pelicanparts.com/uploa...1719234088.jpg
