New brake rotor ?
I purchased new rear rotors for my 85 Carrera which are OEM made by Sebro in Germany and when I got them they had some machined slots on the outer edges of both rotors I have never seen these before on any rotors I've purchased before (many) and am wondering if this is normal or screwed up? Is this some sort of weight balancing technique by the manufacturer? What do you think?
Just because I don't care doesn't mean I don't understand! Gordon Ost '85 Carrera Cab '01 Durango 5.9 R/T '00 Taurus SE- SO's canoe '97 KTM 250EXC FOND MEMORIES: '68 Pont Ventura Conv 389w/trips '99 BMW 323is '71 TR-6 very first car '73 TR-6 restored it-Concours winner '67 Lincoln Conti-suicide doors '70 Challenger-340-6pack slap stk '69 Dart GTS 440-4bl-4spd '73 Moto Guzzi Eldorado |
Hi gost,
These slots are machined in for balancing the discs. The older original discs used clamps inside the vented discs for balancing, and some after-market discs are not balanced at all. So if yours are balanced it is a good sign, I use the same discs on my SC, no complaints! Sebastian
it`s not the speed that kills, it`s the sudden stop! |
I agree, the cuts are from balancing. Looks like they took a lot of material off
Thanks Sebastian and Bill. I was hoping that's what it was. I also thought it may have been a wear indicator, when the rotor wears to 22mm thk there's not much metal left along those machined edges and it's time to change them. 25 yrs of turning wrenches and I see/learn something new about simple rotors. Life is interesting!!
Thanks again. Gordon
