This caught my fancy
Adrenaline Junkie
I'm with you. She is sexy.
Designer King
Lookin' good.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Crew Chief
Here is mine , almost twins
Herbert B. GruppeB #093 Carolinas Region PCA Member National PCA Driving Instructor _______________ '71 911 RSR look '74 914 2.0 '76 911S Targa '83 930S Slantnose (13000 miles) '86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014 '86 951 '87 944 "Life is short , drive Fast" |
I had found the pictures here from 2001. It is about as confused as my car is body work wise. Tell me more about the front bumper. Looks like a chopped IROC.....but is it? I like the look.
Bandwidth AbUser
loose the goofy center reflector and that rear bumper and they start to look good.
Jim R. |
Somatic Negative Optimist
Here is a real Porsche:
![]() Watch for that Maple Leaf in your rear-view mirror!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Okey Dokey.
I 'll watch for it as I am going around you!!! Aw, just kidding there. Where did that bra come from?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
(It is so easy to ignore canadians in black cars )
Licensed User
This isnt going to help much, but I do remember the first car. It was on ebay maybe two years ago. It was an overall optimisitc ad with impressive power and impossible weight numbers. Neat car. IIRC, it was a SWB car originally.
Dane:
Not to highjack this post, but I need to ask you about your WEVO SPS. Was it a true bolt one? Was the fitting of the aluminum race in the torsion bar hole easy? Did you need to shave alot of material? j.p. |
RE: The front bumper. It is a stock item from GT racing...that much I know
![]() JP, my car was a mess from a bad experience with a tow truck operator earlier. So it was as Hayden said, "worse case scenario" of the sets they have sold. Fit and finish was exceptional. Just my bolts were all out of alignment from the under body being tweaked as it was drug over a curb. Previous shop had actually elongated the holes on the spring plates to get them back on. We ended up cutting both sides completely out with a hole saw. The good thing is we were able to use the WEVO spring plate race as a jig to weld those attachment points back into the correct location. Needed to be done anyway. WEVO plates actually made it possible. They were a direct bolt on for the side with the least damage. But you can see where we went from there. Car eventually had a perfect c/b and a fairly good ride height with the (at the time unknown to me) damage. Both were difficult to ever believe we'd get acceptable again. After the major repair and the new WEVO stuff car had an even better CB. Damaged it was with in 10/20 lbs front and back. With the repairs it ended up being just lbs. And much easier to do as well. |
Dane:
Do you think in a car with a virgin hole, the race fitment we be easy? I realize these holes will vary from either manufacturing tolerances or slight corrosion, but in reality all one has to do is remove high spots on the race or torsion hole, right? Once th O-ring is on, does the piece just slide in, or does it get tapped in (with hard plastic hammer)? |
In a clean tub I bet they will either slide in or go in with a plastic mallet easy enough. Call Hayden. He is keeping track of every install and can give you the specifics of what he thinks will happen.
If you don't have yours yet I think the last install sheet was 8 or 9 pages. Way too detailed for me But then I had a bad car to start with so we kinda ditched the directions after figuring that out. Still the install was much easier than the fix. Coming from a car dummy trust me, that is saying a lot
thats one sweet car i do have to say but,,is it me are does the big vent opening on the bottom vallance look just to square to go with the sexy lines and qurve's of this girl's front end ,not to be rude in any way it just seems like someone just bolted a big shiney a/c vent on the front and called it good
i dont know that just my 2 cents farmer
slow down your going to fast! where around that last corner are this one |
I love the color..
The cobalt Blue is a sharp color....
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
Dane,
If that caught your fancy...does that mean...? I hear the rattle of wrenches already Rick
Rick " too many people spend money they haven't earned to buy things they don't want to impress people they don't like" Will Smith |
I like the tail pipes it looks good on the car maybe however a tad bigger
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
