Bird. It's the word...
Fishcop's Avatar
Removing Goo From Gas Tank
Hi Guys
Well I'm having another dose of restoration energy, and have repainted and detailed the front luggage compartment.
I want to restore the rusty (inside and out) tank back to the stippled grey finish. My question... How the fuch do I remove the original rubberised coating?!! I've tried paint stripper, brake cleaner and a sharp chisel. I have a grinder and wire wheel, heat gun and a torch... but question the danger involved with this. Is filling the tank with water a safe option before applying heat or creating sparks?
What have you guys done?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 07-10-2005, 02:36 AM
SteveF_911's Avatar
I just did this.
1/4" wood chisel and about 4 free days. It took me a month all up to get the tank out and cleaned.
I stripped the rubber using a chisel and the angle grinder. Once the paint is off I dropped it into a guy here in Brisbane to clean out the tank in his acid bath.
I then painted it with grey POR15.
Enjoy the Journey your Webbers will love you.
66 911 with S engine
2008 Westfield XTR2
Old 07-10-2005, 03:28 AM
david.avery's Avatar
When I did this on a rusty 71, I used a makita 4" grinder with a braided wire brush attachment. *Caution* wear the proper gear, these things shed wire.
This was much faster than scraping, and it leaves the tank with a nice pre-prime finish.
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 07-10-2005, 06:03 AM
Send a message via ICQ to Mattias Hellore
Re: Removing Goo From Gas Tank
Originally posted by Fishcop
Hi Guys
1-2 hours with a grinder armed with a wire wheel and Beepbeep doing that on my fuel tank.
When the 935 accelerates , the world is a far smaller place. 935/78 Moby Dick
The project 911 page: http://project911.luminasweden.com/
Old 07-10-2005, 07:14 AM
John- I used the electrolisys method on the inside of my '72 tank, and it really did a fantastic job.
In a nutshell:
Fill tank with clean water, add 1 tablespoon Lye per gallon.
Suspend a stainless steel rod (electrode) into the water. (I hung it from a board through the sender opening.)
Make sure electrode is not touching metal tank!
Attach + cable of battery charger to electrode, and neg. cable to metal tank. (filler neck works good).
Do this in a well ventilated area, as the byproduct of this method is Hydrogen!
My tank took 48 hours @2 amps, and came out looking new and grey
inside. It was really bad after sitting over 18 years.
I then flushed it out with a pressure washer, and chunks of rust went all over, but the tank looks mint inside now.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 07-10-2005, 07:33 AM
I did one of mine with a heat gun and scraper (outside). I suspect it took about the same amount of time as the other methods mentioned here. Have fun!
Marv Evans
'69 911E
Old 07-10-2005, 09:35 AM
73911guy's Avatar
The tank in my '73 911 started to rust badly on the inside, and released chunks that got past my fuel filter and clogged the idle jets.
I recently the gas tank done by the Gas Tank Renu process. From what I gathered, they put the tank in an oven and burned off the outside coating. Then they sandblasted the tank inside and out, applied a PVC coating to the inside using kind of a rotational molding movement, and then brushed on a PVC coating on the outside. Cost was around $125 plus shipping both ways. Caution: UPS shipping can be very expensive depnding on how you box up the tank (the size box required puts it into the multiplier of the weight charge).
My criticisms:
Nothing was done to stop or slow the rust in the seam around the edge of the tank, so how long it will hold together is anybodies guess.The PVC coating inside the tank is very thin, there was a plastic "hat" inside the tank that is gone now, and the exterior of the tank looks like it was done by a 4 year old with bad hand to eye coordination. The guarantee applies to only the tank and not any of the connecting tubes, which were painted with just a primer nad started to rust in a month.
In retrospect, cleaning the tank using the electolisys method described here and strippng the exterior with an angle grinder and a cup brush doesn't sound too bad. I'd probably use the Por 15 tank coating on the inside.
Also, I heard that repro tanks wouldn't be available for another 6 months. Given my experience with the importer, I'd add another 6 months to that estimate.
YMMV.
Jim
Old 07-10-2005, 10:28 AM
Fishcop's Avatar
Matt, inspirational photos
Mike, I'll definitely give the electrolysis thing a go. Remarkably there appears to be little rust inside the tank (that I can see), but now that I've gone this far, it makes sense to do the job properly...
Steve, what's the name of the place in Brisbane?
Cheers
John Forcier
Old 07-10-2005, 04:12 PM
