project 911's Avatar
Setting caster
Hi all-
My 71T tracks well, no pulling or anything, but when I start to make any turn the steering seems to take more initial force then eases up. Someone suggested that the caster may need adjusting. The specs in my manual says 6 degrees 5'. The "feet" figures on alignment specs always throws me and I'm not sure what it means or how to measure it. If you just put an angle finder on the strut housing should it just read 6 degrees if it is set right?
Confused...
Any advice?
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 08-20-2005, 05:11 AM
I am my 911's PO
'78 SC's Avatar
The ' is "minutes" (1/60 th of a degree). That would make 6 degrees, 5 minutes equal to 6.0833 degrees.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 08-20-2005, 07:11 AM
Wow... that hurts my brain. Thanks Steve
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 08-20-2005, 07:50 AM
89turbocabmike's Avatar
Steve, here is a link to Smart Racings PDF on using their Smart camber gauge. It explains the process for measuring caster.
http://www.smartracingproducts.com/pdfdocs/011073_smartcamber_manual.pdf
Old 08-20-2005, 09:30 AM
Thanks for that- I'll check it out.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 08-20-2005, 06:58 PM
