Best motor mount set up.. is it.
To go with solid on the rear on the motor and Clubsports on the tranny? I am sure i had heard that somewhere on here before... is that the way to go ..?
-TIA.
Eric
Old 08-23-2005, 05:24 AM
Do you think soild on all mounts are a good idea.?
Old 08-23-2005, 06:52 AM
I like Orange
Cookie Porsche's Avatar
Eric,
What do you use the car for? Road, DE, race...?
I like the solid engine, softer gearbox idea. Otherwise too much noise in car.
Wevo makes a really nice mount for street / sportt. Pricey but nice.
Solid mounts may also stuff your f/i around.
Tom
“Rules are meant to be interpreted…”
http://www.cafe9.co.za
Old 08-23-2005, 07:47 AM
TRACK STUFF. SOME ROAD USE..
I'LL GO THAT ROUTE AND TRY THE SOLID MOTOR AND CS FOR THE TRANNY..
THANKS TOM..
LATERS..
Old 08-23-2005, 08:30 AM
rlh930's Avatar
Stuttgart,
You might want to read the following if you have not already done so:
http://www.pmocarb.com/bulletins.htm
Roger
'87 930
'73 911T
Old 08-23-2005, 08:46 AM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
I use solid motor and sport trans mounts. NEVER have I had a problem with fuel in my PMO carbs or my Webers. I have been running the solid mounts for 3 years now. They are just fine.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 08-23-2005, 10:11 AM
I like Orange
I'll second Mark (also on the Beck's issue!),
I've run PMO, Weber, etc on plenty engines - 3.0, 3.2 and 3.8 and the solid mounts never gave any problems.
We did have one car with fuel problems (carb?) and DID change to the WEVO mounts (and even the SOFT factory mounts). It did NOT solve the fuel problem. When the problem (perculation) was solved we ran solid mounts again.
Solid mounts is the way to go.
Tom
Old 08-23-2005, 10:28 PM
