Help on electrical problem !
911 1989 3.2
When I leave the windows open or sunroof open before and shut off the ignition I could still close them as long as I did not open the door to break the circuit . Now when I turn off the key it won't let me close roof or windows unless the key is on . What's wrong , a relay or what ? Thanks , Vinnie in Ventura |
Driving member
Vinnie, I believe it is the button/switch inside the door frame when you open the door. It will go bad over time.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
